john deere 1050 joystick installation help!!!!
   / john deere 1050 joystick installation help!!!!
That’s what my loader valve looks like. That is the only valve on the tractor nothing else. I don’t have rear remotes or the old two stick fel controller valve. The only thing under the seat is the block where the 2 lines come out for the 3 point hitch the other line goes to the side of the transmission. 10645DA0-17EA-41B6-9150-7FFFBA9C05B3.jpeg
   / john deere 1050 joystick installation help!!!! #52
Kris
I don't understand "He never hooked up the 3 pt hitch." What exactly do you mean by this.
Was there a hydraulic line left off which you have now added?
I just got off the phone with CROSS Mfg's tech guy Greg.
As I described your problem he suddenly felt like he had talked to you earlier today.
We need to be certain your DV valve actually has the power beyond sleeve installed.
Without it there cannot be any pressure going to the 3 pt.
Can you remove the cap I circled in yellow in an earlier photo and see if there is another part inside.
The correct power beyond sleeve is part # 1V2853.
Dave M7040
when i say he never hooked it up i mean he never added an implement to the tractor after he got it back. when i got it the 3 pt will move up and down but i never had an implement on it till now that i added an implement it will not pick it up.i don't have a picture of the plug with me but ill see if i can find one online that looks like what is in there now
   / john deere 1050 joystick installation help!!!! #54
Kris
The CROSS spec sheet according to Greg has mistakes.
In the following illustration I have blacked out the mistakes in labeling ports
Dave M7040
so mr dave what goes where as far as my hoses coming from my tractor?i have 3 steel lines total. how do you think they should be installed? and according to the valve
On which valve? Joystick control valve?
   / john deere 1050 joystick installation help!!!! #57
Kris
You need to decide whose lead you want to follow, Barry's or mine.
Following directions from two different people will just add to your confusion.
I have no problem backing away.
Dave M7040
No sir I’ll take your lead sorry
You’ve been very helpful in trying to get this figured out for me and I don’t know how I could ever repay you and I appreciate all the help you’ve have given me so far in trying to resolve this for me.
2016 Tracker Marine 14ft Jonboat with 16ft Boat Trailer (A48082)
2016 Tracker...
Toolbox (A50860)
Toolbox (A50860)
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
Concrete Bucket for Crane (A50860)
Concrete Bucket...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
