John Deere 1050 Engine Opinion
   / John Deere 1050 Engine Opinion #1
kleinhhl
Sumerduck, VA
John Deere 1050
Hello all,
I have a John Deere 1050 which I am trying to diagnose coolant loss. Sorry for the long post.
After operating at temperature and letting the tractor cool down, the coolant overflow bottle loses about 2" worth of coolant every time. In other words, it's about 2" lower than before running it to temperature and letting it cool down, after the coolant has expanded into the coolant bottle when hot and retracted into the radiator when cooled.
At around 2500 hours, I noticed white smoke from the stack, coolant loss from the overflow bottle and bubbles in the coolant overflow and white sludge from the blow-by tube bottle when running. I tested the cooling system with my Stant coolant tester and it wouldn't hold pressure. I did notice that the radiator had a leak and several hoses had leaks so I replaced all that with new. When I replaced the thermostat, the old one was broken in the bypass/open position.
That left the bubbles in the overflow bottle and the white smoke when running. I figured it was the head gasket at this point so I put a new one on and torqued the head studs at the low end of the spec. The valve cover had white sludge on the inside top when I took it off. For the record, all gaskets and o-rings that I've replaced have been baked on and past their usefulness. I had already done a new crankshaft seal on the front of the engine previously that was baked on...
After the new head gasket, I ran the engine with new oil for about 10 hours and there was still coolant loss and white sludge from the blow-by tube but not as much. I re-torqued the head studs to the high end of the spec. and took an oil sample to send off to Blackstone Labs (see attached report). They reported 1.8% of the sample was water and 0.1% was antifreeze. There was also elevated iron, potassium, aluminum and sodium levels which I can only assume is ring or bearing material???
I have finally just ran a pressure test of the coolant system again with the Stant coolant tester and pressure drops by 3 psi from 14 psi over a period of about 3 minutes. I also ran the tractor with the Stant tester connected and the pressure rose pretty steadily and slowly as the tractor warmed up. There was no wild jumping from the Stant coolant tester needle indicating major pressure from combustion getting into the cooling system. There are no bubbles in the coolant overflow tank anymore either when running and warmed up at idle or 1500 RPMs or 2000 RPMs.
My next thought is maybe the cylinder sleeve o-rings are leaking. I don't think there is a crack in the block or head although that could be a possibility.
It would be $50 in parts to replace the cylinder sleeve o-rings only but obviously that would entail a lot more work that may be not worth it. I would also need a cylinder sleeve puller tool which seems to start at $450 on eBay for a Chinese knock-off.
If I rebuilt the engine with new pistons and rings, I would need to put new sleeves in as well (all from Hoye Tractor) and a new head gasket because the original parts are no longer available at a decent price from John Deere. That would be $1,000 in parts plus the cylinder sleeve puller tool.
Any thoughts or opinions? Am I missing anything? Don't want to spend the money unnecessarily...
Thanks for any responses!
   / John Deere 1050 Engine Opinion #2
These 50 series tractors with the 3 cylinder Yanmar's have a reputation for cracking heads. I have recently gone thru a couple of 3T90J engines out of JD 950's. I'll be happy to share what I have learned. The sleeve puller isn't a big deal to make. If you pull the crank you will also need special pullers for the front and rear main bearings. Send me a message with a phone number if you would like to discuss. I'll share what I can here but it would take several pages of writing to share it all.
   / John Deere 1050 Engine Opinion #3
Oh, and just out of curiousity who's head gasket did you use? I have noticed a big difference in the quality of the gaskets I have ordered.
Okay, thanks for the replies... one thing I hadn't done yet was have the head checked over for cracks. When I had it off, I just scraped the old gasket material off and put it back on. Would a magnaflux test be the appropriate test for cracks in this head?
The head gasket set I bought came from dieseltractorparts.com and it was P/N 121422-99040 which I can't seem to find on their site anymore. That part number appears to be a Yanmar part number and the packaging said Yanmar and had Japanese writing on it. It was listed and sold as the head gasket set for John Deere 1050's with S/N's newer than 089473...
   / John Deere 1050 Engine Opinion #5
The first tractor I repaired had a similar issue and the previous owner had already done the head gasket. I assumed the tractor had a larger issue. I took the head to the shop and after looking at it the old guy said I had a rare head.......one that wasn't cracked!
Did any of your 8 hold down studs unscrew from he block? I believe the previous repairman reinstalled at least one stud with the nut more or less seized to the stud. While we've all done that on less significant connections that technique most likely won't result in the correct tension in the stud. It didn't in this case and their new head gasket leaked almost immediately.
I think they start with a pressure test on the head and magniflux if it fails the pressure test but I'm not 100% sure.
If you find an old school shop they can repair many of these heads.
It's interesting that you mention the head studs... I was unable to get two of them unthreaded from the block. The rest all came out and when I re-installed them, I oiled them per the JD 1050 tech manual. The other two were not oiled on the block side obviously. This fact has been at the back of my mind for a while but I didn't know if it would cause the head gasket to leak. It's worth a shot to try to get them loose, chase the threads and re-install...
Sounds like between checking the head for cracks and doing the head studs right, that may be my first step...
Thanks again!
   / John Deere 1050 Engine Opinion #7
I would give serious thought to a compression check prior to pulling the head. It will require pulling the injectors. I can walk you thru that if you decide to pull them. I'm assuming they'll be stuck but maybe the've already been out in recent years.
I wouldn't be concerned with the two studs that wouldn't come out. I assume you installed all 6 remaining studs prior to installing the head. Bottom line, when you torque you want the nut turning on the stud and not the stud turning in the block. If that was the case I would assume the tension is correct.
   / John Deere 1050 Engine Opinion #8
Can you pull the valve cover and oil pan and do the coolant pressure test again? Maybe you could actually see the leak to tell you which way you need to go.
   / John Deere 1050 Engine Opinion #9
could he pull the valve cover and pressurize the cooling system, first, only pulling the pan if he experiences loss, and cant find source? Also please make sure you pressure tester does not leak.
All good suggestions... I will try the coolant pressure test with the valve cover off and report back.
Thanks all...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2014 Ford Escape (A50324)
2014 Ford Escape...
