jj or anyone help please
/ jj or anyone help please #1
rayclar
prince township , ontario, canada
kubota 4310hstc
Ive read many post about kubota loader valves that freeze up and they say to drill a 3/32 hole to drain the water. Is that to drill on the end that the cables hook to or the opposite side? also i have a l4310hstc model Thanks ray
/ jj or anyone help please #2
They are talking about the caps on the bottom of the valve that cover the float section and other add-ons.
You can also fill the caps with some waterproof grease.
/ jj or anyone help please #3
Agree with JJ - I'd go with the grease. Everything around my place with a hole big enough to drain water also seems to attract bugs looking for a new home... Steve
UPDATE , today i drilled a 3/32 hole in each cap. It drained about 1/2 oz of water from each. Then flushed them with wd40 and moved the control every which way possible. All done still on tractor. Hopefully this will solve the freezing problems i had. No grease as im going to block the holes with rubber patch and hose clamps. Then if it needs flushing with wd40 i just have to remove the clamps. Thank all. ray
/ jj or anyone help please #5
Try Fluid film or PB Blaster, MUCHO better than WD40 as a lubricants.
/ jj or anyone help please #7
Fluid film is sold at most JD dealers, PB Blaster is available almost anywhere.
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2016 Ford F-150 Ext. Cab Pickup Truck (A61573)
2016 Ford F-150...
2006 Kenworth W900 Day Cab Truck, VIN # 1XKWDB9X76J112716 (A65563)
2006 Kenworth W900...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
2012 Ford F-350 Western Mule 1,500 LB Crane Service Truck (A61573)
2012 Ford F-350...
2019 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2019 Freightliner...
