Chipper Jinma chippers
/ Jinma chippers #101
JerryK said:
Dougster, you can fix it, make it better than new. :) While you are working on it, read this, and ponder...
http://www.hse.gov.uk/foi/internalops/sectors/ag_food/1_05_05.pdf
Well, isn't that special! :D
I guess all of us here know the Model 6 is fundamentally unsafe. Looks like someone in the UK figured that out as well. I'm betting that yours is the all-new "safer" version. Only time will tell if some sort of legal action is taken here to recall and/or modify these crazy machines. :rolleyes:
Dougster
/ Jinma chippers #102
Last week I received a 'non-Jinma' chipper. The feed roller shaft assembly is pitiful, and it totally failed after 30 minutes.
It appears to me that ALL of us need the shaft assembly pictured in the two photos Tommy kindly posted. Does anyone know who supplies the shaft assembly in Tommy's photos?
I had a drive line shop fab one for me, but it's somewhat too long for the 8 1/4" shaft-to-shaft spacing. I'm trying to find a welder to come out and extend the gearbox mounting plate 3" so that the gearbox can be mounted farther away from the feed roller. I believe that extra distance will both flatten the angle and allow this really heavy-duty U-joint assembly the travel it needs.
/ Jinma chippers
Howdy, John ran across the chipper in EBAY that had the driveshaft in it...
eBay: Wood Chipper 6"dia. WC6 Cat.1 3pt 25-45HP Rating (item 170110767493 end time Jul-09-07 09:39:00 PDT)
The company that sells it says it has parts on hand to sell, so I would contact them. There is already a link somewhere on this site to a video on U-Tube of a chipper that was modified with a stronger/longer driveshaft than what is on this unit on EBAY, something simular to what you want to do. You're right, the farther you can get away from the roller the less angle you end up on the universals. The mod that is on U-Tube has an idler pulley to keep the belt from rubbing on the old gearbox platform, but I plan on cutting the old platform off and will make my own farther out, maybe someday...............
/ Jinma chippers #104
Pete in FL said:
Last week I received a 'non-Jinma' chipper. The feed roller shaft assembly is pitiful, and it totally failed after 30 minutes. It appears to me that ALL of us need the shaft assembly pictured in the two photos Tommy kindly posted. Does anyone know who supplies the shaft assembly in Tommy's photos? I had a drive line shop fab one for me, but it's somewhat too long for the 8 1/4" shaft-to-shaft spacing. I'm trying to find a welder to come out and extend the gearbox mounting plate 3" so that the gearbox can be mounted farther away from the feed roller. I believe that extra distance will both flatten the angle and allow this really heavy-duty U-joint assembly the travel it needs.
Interesting idea. Meanwhile, we are all trying to get Tommy to put together an upgrade kit... in particular for the Jinma's... that is, if they don't get recalled (or otherwise outlawed) first!!! :rolleyes:
Dougster
/ Jinma chippers
Chippers mine now, they can't have it. Lest they pry it from my cold dead hands............................ In a few more days, I'll have enough things changed on it that they wouldn't reconize it, anyway. :)
/ Jinma chippers #106
Well, gotta tell you Jerry that the UK PDF you posted has me thinking that a similar USA PDF can't be far behind! Lots of government officials out there trying to keep you and me safe... and keep their nifty government jobs while they're at it! :) Shall we bet on how much longer it will be before these things are discovered and banned? :rolleyes:
And the worst part? So far, I couldn't care less if they DID recall mine. :eek: I'm not a very happy camper so far. Still the bug Jerry... Still the bug. :(
Dougster
/ Jinma chippers #107
That PDF is kind of an eye opener. You have to be mighty careful using it. Sometimes you overlook the safety for the price but the aggravation and danger isn't sometimes worth it with the Chinese and OTHER foreign products. I'm not putting any product down just asking where you draw the line? If you don't mind aggravation and like to walk the razors edge fine. I like products that are dependable and safe from the get go. I walked that route before and took my losses. I am happy with what I have now. I have a foreign product but it has a proven safety and track record. When I turn the key I know what I'm getting..And it starts every time.
/ Jinma chippers #108
Here's the email response I received from the company that has the the feed roller driveshaft assemblies that are shown in the photos Tommy posted:
Yes we have them available. They are $93.00 plus $12.00 for shipping and handling. Minimum working distance on 1/2" squared end is 10 1/2" Let me know if you would like one sent.
Thank You
Keith Powell, General Manager
Betst Products, LLC.
Keith@BetstCo.Com
Voice: 541-895-3083 ext.312
EFax: 904-216-2059
/ Jinma chippers
I don't know what the going rate for parts for your broken wobble-shaft except this link to CircleG...
Jinma Wood Chipper Parts : Zen Cart!, The Art of E-commerce
Using their prices, the price they quoted you sounds pretty good. My only question would be what they mean by the 'square shaft end'. I would give them a call [they list an 800 number on their EBAY ad], and make sure it will fit your unit. My unit has a male 1/2" [or metric lookalike] on both ends, clutch and feed roller [driveshaft has female on both ends], and maybe their clutch unit is made different. But maybe you could get one of them, also. Good luck, Jerry.
/ Jinma chippers #110
Not to confuse things, but this guy is operating up from our street... Make it Jinma #4
tytaninternational
Anyone have any thoughts on this one? I like the footing, but what scares me about all of these is getting parts...
Anyone have any final comments on the BETST version? They are just south of us... And there is a Jinma dealer a bit closer...
Carl
/ Jinma chippers
tytaninternational
Carl
I like the driveshaft in the Betst, although I wish it was longer and maybe a little heftier. I'd be interested in finding out what kind of driveshaft is in the Tytan. If you take a real good look at these units, the basic guts area of the chipper is just about the same. The Tytan has an adjustable base, a bigger chute, and seems to have better designed guarding. Betst has a pretty good price on EBAY, and a cable type disconnect [even has a foot operated pedal].
You could contact Tytan about the parts, most of the dealers sell at least a basic list of parts. I bet the Tytan, Betst, Jinma, and my unit all have the same flywheel/bearings/pulleys/gearbox/knives. Just the sheet metal and controls are different. The parts list on the Tytan site shows an exploded diagram that is common to all these units, no matter what they really look like.
/ Jinma chippers
Heh Dougster, now we have Tytan saying " we took the first chipper to China 13 years ago to be built ". And we have Betst saying they are a pre Jinma chipper, too. Then there is the Jinma, the the copy of Jinma, then finally......my [sniff]....copy of a copy of a Jinma. Sort this all out for me, it's too confusing. :)
/ Jinma chippers #113
I hear you Jerry! My head is still spinning. :rolleyes:
All I want to know is when do the recalls start??? :confused:
The Bug
/ Jinma chippers #114
Recalls????????
There's no stinking RECALLs with stuff from China.......:p
You got the steel (sort of).
You got the belts (sort of).
You got the bearings (sort of).
You got the knives that will sort of last.
You saved about 3x what a real chipper costs.
You have (or should have) average to above average intelligence in operating this to avoid killing yourself or anyone else.
Now, go out and (as someone else has already said) STOP THE BURN!!!:D
/ Jinma chippers #116
Dougster said:
And since when did that stop one "safety recall" of one single item the government didn't want you to have??? :rolleyes:
That's true, and more so in some states than others. Just keep it for "personal use" only, or modify as needed.
I love it (not really) when they try to HEP us. Makes you really appreciate places like the Lone Star State.
/ Jinma chippers #117
MadDogDriver said:
That's true, and more so in some states than others. Just keep it for "personal use" only, or modify as needed. I love it (not really) when they try to HEP us. Makes you really appreciate places like the Lone Star State.
The Lone Star State is a wonderful state. In my previous life, I visited and worked there for extended periods. It almost became a second home... I kid you not! I've even got family there...
But I digress. The issue on the table is a federal safety recall of these horrible, deadly, Chinese chipper devices... and because I got a crappy one at a crappy price, I am officially ALL FOR IT!!! :D
Dougster
a.k.a., The Bug
/ Jinma chippers #118
Last Friday I had a local driveshaft company make me a feed roller driveshaft assembly. They used heavy duty components, such as 7/8" square shafting. The square female ends were cut off the original shaft, machined, and pressed into the new yoke [1 1/4" diameter] The sole problem comes about because these beefy components take up space, and space between shaft ends is very limited, as we all know. The unit cost $139 including tax and took them 2 hrs to have ready for pickup. The components were the smallest sizes they keep on hand but perhaps another shop would have a wider selection. What I have now is certainly overkill, which perhaps isn't a bad thing.
I'm more & more convinced that the best long-term fix is to move the gearbox location away from the feed roller shaft ~ 3". I plan to cut off the existing vertical angle leg and weld on a 3x3x 1/4" angle. Torch out appropriate slots for all the bolts, add bracing underneath, perhaps cut the existing bracket so the belt doesn't rub. Problem is finding a mobile welder -- those guys used to be all over the road and now they've disappeared around here
Opinions?
/ Jinma chippers #119
Dougster said:
...The issue on the table is a federal safety recall of these horrible, deadly, Chinese chipper devices... and because I got a crappy one at a crappy price, I am officially ALL FOR IT!!! :D
I just got one too (and acknowledge that there are several improvements needed to improve it's reliability and performance). I'm sorry about the condition of how your's arrived.
Fortunately for me, mine hums quietly and does a great job eating everything I've put on it's plate.
As for price.......??? I'm happy having with the price I paid, for what it does, especially when compared to other chippers and their prices.
So.......I personally don't need Big Brother telling me what I can do with my equipment, on my property, operated solely by me. Maybe I'm being naive about the potential risks operating this, but I don't think so.
/ Jinma chippers #120
MadDogDriver said:
I just got one too and I'm sorry about the condition of how your's arrived. Fortunately for me, mine hums quietly and does a great job eating everything I've put on it's plate. As for price.......??? I'm happy having with the price I paid, for what it does, especially when compared to other chippers and their prices. So.......I personally don't need Big Brother telling me what I can do with my equipment, on my property, operated solely by me. Maybe I'm being naive about the potential risks operating this, but I don't think so.
You'll get no argument from me MadDog. Personal responsibility is a fine thing. I am half joking here... but also half serious. I am not a happy camper about the way that mine arrived. I do not have time for the nonsense of fixing all the damage in addition to the known and necessary upgrades. The latter were factored into my plan... the damage was not. Some damaged parts in particular may pose an unacceptable long-term safety hazard... and I am still debating what to do about it. There are clearly options... but it may be better if I just sell this one "as-is" and order in one of the later generation machines. It will be a hard pill to swallow either way... but I don't have a great deal of confidence & trust in the one I received. :mad:
Dougster
case 370 glass door never installed (A61307)
case 370 glass...
UNUSED WOLVERINE MPF-11-2500G MINI PALLET FORKS (A62131)
UNUSED WOLVERINE...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
New/Unused Quick Attach Post Driver (A61166)
New/Unused Quick...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
