Chipper Jinma chippers
/ Jinma chippers #161
Good idea! I was wondering what to do with all that angle iron that came with the thing! Now what can I do with those heavy metal plates?
Originally I was going to sell the Yanmar 18hp, but now it looks to be a good candidate for the chipper. It's at the lower end of the recommended power rating but most of the work we have to do here is Palo Verde trees and Cat Claw acacia. Probably light duty compared to some of you other guys.
Then why did we go for such a big chipper? Well, we already wore out one of those homeowner style manual feed 6 HP chippers! Bought a 10hp Troy-bilt that has done fairly well, but still barely adequate for the job.
/ Jinma chippers
Some of the heavier angle on the base of the shipping crate might be heavy enough for braces, but I would be using 1/4" thick 2" X 2" for the base, at least. That thing is pretty heavy, and if you ever set it down hard that little angle would have lots of more angles in it, REAL QUICK !!! I cut the weld off of mine and saved it, but more for light projects.........someday...... As for that old base, take some time someday and price a one foot square piece of 1/4" thick steel sheet someday. Afterwards, you will carefully set those pieces somewhere safe and covet them for some future project, or leave in your will for your Grandkids. Steel has really went up in price lately.
/ Jinma chippers #163
The advice is appreciated. So I went and cut 4" off the bottom of the original base anyway. Guess I was too lazy to design a whole new base. Besides, after all the work my back is killing me. So I torched it off with little oxygen to spare, and welded the leftover angle pieces back on to the bottom.
May not be pretty, but it looks like it'll work.
Don't know it it's just my tractor, but I had to get a longer top link. 25" was the maximum length of the one I used when I had the box blade on it.
Tomorrow will be the final test, will it fit?
/ Jinma chippers
Looks like it should work fine. I have two toplinks and I had to use the longer of the two on my chipper. That chipper you have looks a lot like the ones Betst is selling on EBAY. If so, it might have the universal joint type feed roller shaft, which is a plus. Enjoy your chipper, and wear ear plugs... :)
/ Jinma chippers #165
I had to get a longer toplink for mine as well, due to the fact that I have a Quick Hitch.
/Todd
/ Jinma chippers #166
It looks as though Jinma has made some modifications to the chipper. The picture chuck4389 provided looks like they have gone to using cable linkage rather than the rigid rod linkage that is on mine.
Have fun with it and let us know how it works for you.
/ Jinma chippers #167
OK gang! Got it running finally. Followed most of the advice here, changed the zerks, inspected, and greased everything carefully, set the cutter blade clearance to .020". That was kinda tricky because I had to remove the shields to see what I was doing. But it was worth the extra time, it's not very easy to see from the front.
Noticed that both blades are not aligned to each other, one blade has slightly larger clearance (maybe .030' more) on the outer edge. Also, the anvil plate that was installed in it was ground wrong, the bevel was in the wrong direction, so I used the spare plate that came with it.
After a bit more bending of sheet metal, tapping to restore threads, and other miscellaneous tasks, I attached it to the tractor. The weight of this monster makes it feel like the tail is wagging the dog.
We worked for about an hour and did more in that hour than we could have done with the 10HP Troy for all afternoon. So far it's working great, the wife is ecstatic. I feel like now I could write a book of advice on this thing. It certainly would be better than the manual that came with it!
It was sold as a Jinma, but there is no data plate, no name, no model no. If anyone is interested in more pictures for comparison, I can do that.
Final word of advice, get red, it matches the blood.
/ Jinma chippers #168
From the pic,it is not a Jinma but sounds like you have it working good now
Some parts will innerchange some won't.Whenever you do need parts make sure that you tell them it is a WC-06 Chipper,the Jinma is a JM-06.
Tommy
Affordable Tractor Sales
/ Jinma chippers #169
Thanks affordable. I see that you stock replacement parts.
Hope I don't need them very soon, but you are bookmarked.
/ Jinma chippers #170
I just bought a used Jinma chipper, probably a couple of years old, but the seller could not find any of the documentation, which I understand is pretty minimal anyway. (He's still looking.) I'd like to get a parts diagram/list and any specs on oil, tensions, settings, etc. Does anyone have anything that they could post, email, or fax? Thanks. I've read a lot of the posts on modifications, belts, etc., which I'm going to implement.
/ Jinma chippers #171
I'd scan my copy BUT looking at Chuck's chipper and reading what Affordable said, I'd have to say that I don't own a Jinma.
So who makes the WC-06 ?
/ Jinma chippers #172
I have all 19 pages in JPEG format, about 4.7 meg total.
Also have it in PDF format, about 48 meg total.
How would you like it?
You can also find detail photos at ranchhandsupply.com.
/ Jinma chippers #174
Can someone give me a number for a US made replacement V-belt that will fit the feed drive on the Jinma chipper. Thanks. I did see a post about an A cross section belt, but I don't think that's correct. Someone else suggested I use a Napa BXV42 belt, but that's not a good number. BX42 is a good number, but I'd like to get confirmation. Thanks.
/ Jinma chippers #175
Just take in your old belt and have them match it up visually... Works almost 100% of the time ;)
/ Jinma chippers #176
The old belt is gone. My grandson just "confessed" yesterday that he tossed it in the woods at the place where we bought the machine, thinking that it was so badly trashed that we didn't want it for anything.
/ Jinma chippers #177
Try a 4L400, that's 40" circumference at the pitch line.
Just to make sure, measure the outside circumference with
a tape measure, should be about 41", then subtract about an inch.
Measuring will take about 4 hands or a lot of clips.
In standard belt numbering systems, 3L, 4L, etc is the width of the belt.
The last series of numbers is the pitch circumference in inches times ten.
Most good hardware stores should stock this and they can also measure
your old belt.
/ Jinma chippers #179
A 4Lxxx is a plain V-belt, not cogged.
