Jinma 254 igintion problem
/ Jinma 254 igintion problem #1
john carr
Greenup, IL
Tractor King 254 and iseki
Help, my Jinma 254 tractor blows the fuse when I try to start it. I have replaced both the switch on the clutch and the ignition switch. When I turn the key I sometimes get the starter to run and have started the tractor but then find the fuse is blown when I go to start it the next time. Other times it just blows the fuse. What else can cause the fuse to blow. Bad glow plug?
Thanks in advance.
John Carr
/ Jinma 254 igintion problem #2
i would check the glow plugs next. 1 or more maybe shorted to ground. also check the wiring for the glow plugs.
/ Jinma 254 igintion problem #3
Thanks in advance.
John Carr
On mine, you turn the key clockwise to start with the glow plugs, counter clockwise to start without. Try starting counter-clockwise and see if that helps -- assuming you don't need glow plugs this time of year.
Thanks for the info. I rewired the glow plugs using #12 wire on a separate circuit. Everything seem to work Sat. Now it's Monday morning and I seem to be back to square one except the Glow plugs are not the problem. When I tried to start the tractor it initially fired. But when I tried it a second time it started to blow the fuse again. Also when I turn the switch counter-clockwise nothing happens other than the lights will work. I am next going replace the wire from the switch to the starter with a in-fuse and see if that is the problem! Any ideas
3Pt Backhoe (A66285)
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
80003CFL (A61568)
80003CFL (A61568)
2015 GMC 3500HD Flatbed Truck  6.6L Duramax Diesel (A63688)
2015 GMC 3500HD...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
