JD790 Dash Gauges Indicate Problem?
/ JD790 Dash Gauges Indicate Problem? #1
netroglycerin
Could the fact that the fuel and temp gauges are not working but the fuses are all OK be on purpose (to indicate a failed component such as the seat safety switch, etc.)? I am working on the tractor for a no-starting problem but even with a new battery and air filters, I was next replacing the fuel lines and trying to eliminate an air leak - but noticed this gauge failure while turning the tractor over. Any hunches out there?
/ JD790 Dash Gauges Indicate Problem? #2
No, the gauge circuit is a separate circuit.
Does it crank over at all ?
If it does crank, do you get any smoke from exhaust ?
If no smoke, did you try removing your fuel shut off solenoid ?
You say air leak in lines ?
/ JD790 Dash Gauges Indicate Problem? #3
I suspect you have read bout my latest ordeal :D
An apparent irrelevant display failure warning sequence is indeed sometimes programmed into machinery control computers to alert technicians to a specific problem not necessarily directly related to the warnings, apparently this widely used in aviation. Typically the sequence would make no sense to the operator/driver/pilot. I learned this while googling my own tractor issues.
If your tractor turns over then the problem is likely not NSS related and the seat switch not the issue. I don't dare ask but here it is anyway: since your fuel gauge is not working have you made sure you have fuel in the tank?
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2014 Ford Escape AWD SUV (A66738)
2014 Ford Escape...
1 PALLET OF MISC TRUCK PARTS (A66091)
1 PALLET OF MISC...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2010 48 ROLL OFF TRAILER (A67714)
2010 48 ROLL OFF...
