JD790 Dash Gauges Indicate Problem?
/ JD790 Dash Gauges Indicate Problem? #1
netroglycerin
Could the fact that the fuel and temp gauges are not working but the fuses are all OK be on purpose (to indicate a failed component such as the seat safety switch, etc.)? I am working on the tractor for a no-starting problem but even with a new battery and air filters, I was next replacing the fuel lines and trying to eliminate an air leak - but noticed this gauge failure while turning the tractor over. Any hunches out there?
/ JD790 Dash Gauges Indicate Problem? #2
No, the gauge circuit is a separate circuit.
Does it crank over at all ?
If it does crank, do you get any smoke from exhaust ?
If no smoke, did you try removing your fuel shut off solenoid ?
You say air leak in lines ?
/ JD790 Dash Gauges Indicate Problem? #3
I suspect you have read bout my latest ordeal :D
An apparent irrelevant display failure warning sequence is indeed sometimes programmed into machinery control computers to alert technicians to a specific problem not necessarily directly related to the warnings, apparently this widely used in aviation. Typically the sequence would make no sense to the operator/driver/pilot. I learned this while googling my own tractor issues.
If your tractor turns over then the problem is likely not NSS related and the seat switch not the issue. I don't dare ask but here it is anyway: since your fuel gauge is not working have you made sure you have fuel in the tank?
2012 FREIGHTLINER M2112 S/A GARBAGE TRUCK (A66091)
2012 FREIGHTLINER...
RANGER S/A TRAILER W/WELDER (A67714)
RANGER S/A TRAILER...
2009 JACK COUNTY KILL TRAILER (A67714)
2009 JACK COUNTY...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
2025 Kubota RTV520 4x4 Gas Utility Cart (A66734)
2025 Kubota RTV520...
