JD4500 Problem
   / JD4500 Problem #11
Good ideas here --- installing the cab and the changes to the main wiring harness involved with that --- could very well be the culprit.
I have had problems with added halogen lights and work lights that pushed my alternator to it's limits such that it couldn't maintain my battery over time when I used the tractor often with all the light's on.
When I'd switch the light's on; everything would drop-dim and I'd have to pull the rpm's way up to get any brightness and the alternator/voltage regulator would kick in and things would improve but if the rpm's dropped... Well, orange light from a halogen light is not a pretty thing at all!
I've also experienced having diodes fail on the alternator and it would (charging) kick in and out randomly and as a result would not maintain the battery charge over time.
That said, not having any fuse problems or melted-hot wires and such pointed away from a loose wire or poor ground issue... IMO.
But a good check on the wiring harness and whatever changes were made during the cab install would be a good exercise.
AKfish
   / JD4500 Problem
Akfish - No additional connections were made when the Curtis Cab was installed (I couldn't afford them). All the lights that came with the tractor are still on it. I'm leaning toward a grounding issue or at the least, a corroded battery terminal, etc...
Thanks for the ideas, though. I'm not ruling anything out until I figure out what is going on.
Roger
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
DEUTZ MARATHON...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
KUBOTA M900 TRACTOR (A59823)
KUBOTA M900...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
