JD4500 Intake Heater Problems
/ JD4500 Intake Heater Problems #1
MMH
Murrysville, PA
JD 4500
I have a 4500 that I have some starting problems on. Can someone outline the procedure to check out the intake heater system?
/ JD4500 Intake Heater Problems #2
The easiest way is to take the intake hose off at the engine, turn on the key and feel for heat.
On Edit: If it has the setup as my old 4310, you have to push in on the key in the on position to make it work.
Thank you. Checked it out & it is fine. Not only hot, but red hot...
/ JD4500 Intake Heater Problems #4
That grid does get very hot.
