JD4500 Intake Heater Problems
/ JD4500 Intake Heater Problems #1
MMH
Murrysville, PA
JD 4500
I have a 4500 that I have some starting problems on. Can someone outline the procedure to check out the intake heater system?
/ JD4500 Intake Heater Problems #2
The easiest way is to take the intake hose off at the engine, turn on the key and feel for heat.
On Edit: If it has the setup as my old 4310, you have to push in on the key in the on position to make it work.
Thank you. Checked it out & it is fine. Not only hot, but red hot...
/ JD4500 Intake Heater Problems #4
That grid does get very hot.
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
(2) FORESTRY TIRES ON RIMS (A64276)
(2) FORESTRY TIRES...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2016 Peterbilt 320 EZ Pack 40yd Front Loader Garbage Truck (A61573)
2016 Peterbilt 320...
KMC 3pt 5' Rotary Tiller (A64119)
KMC 3pt 5' Rotary...
