JD4500 Intake Heater Problems
/ JD4500 Intake Heater Problems #1
MMH
Gold Member
Murrysville, PA
JD 4500
I have a 4500 that I have some starting problems on. Can someone outline the procedure to check out the intake heater system?
/ JD4500 Intake Heater Problems #2
The easiest way is to take the intake hose off at the engine, turn on the key and feel for heat.
On Edit: If it has the setup as my old 4310, you have to push in on the key in the on position to make it work.
Thank you. Checked it out & it is fine. Not only hot, but red hot...
/ JD4500 Intake Heater Problems #4
That grid does get very hot.
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2022 Behnke Trailer (A60352)
2022 Behnke...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
