JD4100 Install Neutral switch 1998
   / JD4100 Install Neutral switch 1998 #1
Bucky3d
John Deere 4100
My neutral swt seams to be acting up is my guess. Having to work forward ->neutral<-- back and forth trying to find the spot to turn the engine. I make sure my PTO is in neutral, step on the clutch, release, range lever and it will start once I find that magical position. I think it final went bad.????
My JD4100 1998 (Gear Type) was doing just fine until I stalled it in wrong gear.
As mentioned above: I put the everything in Neutral, worked the Gear Range Lever, won't crank again - got plenty of battery.
How to test if Bad?
Hard to Replace?
Does the PTO have a swt also?
Any other place have this blocking feature other than the seat?
bucky3d@yahoo.com
   / JD4100 Install Neutral switch 1998 #2
I have a PDF of the tech manual you're welcome to, shoot me your email if wanted
Joe
Joe,
Not sure if you got my message, I surely do want the PDF Manual and thasnk you so much.
Ralph
bucky3d@yahoo.com
Joecdeere,
Did you get to send that PDF you mention?
Look forward to seeing it.
Thank you
Bucky3d Ralph
bucky3d@yahoo.com
   / JD4100 Install Neutral switch 1998 #6
on the way now
Got it Joe, many thanks for that document..
Ralph (Bucky)
Joe,
I can't thank you enough for the Tech Manual, gave me everything I needed and more. Got the "No Start" problem solve. It traced the electrical back to my solenoid, loose connection.
Thank you again.
Bucky3d
   / JD4100 Install Neutral switch 1998 #10
good deal!
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
