JD4100 Install Neutral switch 1998
   / JD4100 Install Neutral switch 1998 #1
Bucky3d
John Deere 4100
My neutral swt seams to be acting up is my guess. Having to work forward ->neutral<-- back and forth trying to find the spot to turn the engine. I make sure my PTO is in neutral, step on the clutch, release, range lever and it will start once I find that magical position. I think it final went bad.????
My JD4100 1998 (Gear Type) was doing just fine until I stalled it in wrong gear.
As mentioned above: I put the everything in Neutral, worked the Gear Range Lever, won't crank again - got plenty of battery.
How to test if Bad?
Hard to Replace?
Does the PTO have a swt also?
Any other place have this blocking feature other than the seat?
bucky3d@yahoo.com
   / JD4100 Install Neutral switch 1998 #2
I have a PDF of the tech manual you're welcome to, shoot me your email if wanted
Joe
Joe,
Not sure if you got my message, I surely do want the PDF Manual and thasnk you so much.
Ralph
bucky3d@yahoo.com
Joecdeere,
Did you get to send that PDF you mention?
Look forward to seeing it.
Thank you
Bucky3d Ralph
bucky3d@yahoo.com
   / JD4100 Install Neutral switch 1998 #6
on the way now
Got it Joe, many thanks for that document..
Ralph (Bucky)
Joe,
I can't thank you enough for the Tech Manual, gave me everything I needed and more. Got the "No Start" problem solve. It traced the electrical back to my solenoid, loose connection.
Thank you again.
Bucky3d
   / JD4100 Install Neutral switch 1998 #10
good deal!
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
2014 AMERITRAIL, INC. TUGGER TRAILER (A50854)
2014 AMERITRAIL...
2007 Pace American JT716TA2 20ft T/A Enclosed Trailer (A49461)
2007 Pace American...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
