JD2240 Utility
/ JD2240 Utility #1
jorswift
Upland, IN
JD955, MF1528, JD2240, JD 4300, Ford Jubilee
Hey all,
Looking at a '79 2240 4wd with fel. Tractor is about 3 hours away so I want to be on my toes checking it out. He sent me a video, but that's hard to tell. Said no leaks and everything works as it should. Said spent about 5k replacing some hydraulic lines, clutch, seals, etc. I have a newer jd4300, so know a little but nothing about these monsters. Thanks.
/ JD2240 Utility #2
We have two older JDs, but don't know anything about the older 20 and 22 series - except they were the Mannheim JDs - powerful & heavy with a closed center hydraulic system and a powershift tranny.
You are probably a better mechanic than most to even be considering it. Maybe someone here knows about them. Consider posting the video.
/ JD2240 Utility #3
older 20 and 22 series and a powershift tranny.
Utility 40 series had a hi/lo that was optional making them a 16 speed instead of 8. Maybe your thinking of the 40 series rowcrop that had a 8 speed power shift option
/ JD2240 Utility #4
Maybe the OP will post the video. Then we can see if this one has the powershift tranny or not.
/ JD2240 Utility
I can post video when I check it out. From everything Ive seen online, i see 2 sets of shifters. So guessing it has hi/low gearing? But wont know for sure until the 28th.
/ JD2240 Utility #6
Range 1,2 and reverses on left. Cannot change those unless stopped. Gears on left. Gears can be shifted on the move with clutch. If it has the hi/lo it will be a lever left of steering wheel. If it is hi/lo that can be changed with no clutch. That lever could also be a reverser or no lever. Just depends how equipped.
/ JD2240 Utility #7
This is what op will see. Nothing power shifting about it.
/ JD2240 Utility
I don’t see a left lever of the steering wheel in the pics they sent. But will find out tomorrow.
/ JD2240 Utility #9
If no lever it is a 8 speed. Just going to be an open hole or a plug in it.
/ JD2240 Utility
So picked up the tractor yesterday. It does not have the hi/lo on the left side. Looks to have just throttle on right of steering wheel, hi/low/reverse on left and gears on right stick. Anyone happen to know the shifts patterns?
/ JD2240 Utility #11
/ JD2240 Utility #12
/ JD2240 Utility #13
/ JD2240 Utility #14
If '79 is in fact the true year this is the shift pattern. There are 2 different styles of the 40 series. 76-79 and 80-82 and I wasn't sure of the break. We had both in 2440. Early and late model. Early had park and late had parking brake.
2022 EZ-GO ELITE...
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
