Jd1020 hydraulic problems
/ Jd1020 hydraulic problems
I can turn both shafts by hand. Thanks for heads up on washers and tool That tool doesn’t come cheap. But while I’m in there might as well change it.
Does anyone have a parts number for packing or seals for the low pressure lines going to the housing on jd 1020
/ Jd1020 hydraulic problems #24
See if your dealer will loan/rent you the tool. My dealer loaned me their tool, but that was over 20 years ago, before a Mega dealer bought them out.
/ Jd1020 hydraulic problems #25
You may as well also buy the gasket, O-rings/packing for the clutch housing to transmission case split. Not knowing your serial number, I did not list P/Ns
/ Jd1020 hydraulic problems #26
workin fool
I hope your tractors engine serial # is above 035895- because rear main seal for lower serial # costs $387.75 when procured from JD.
workin fool
Yes serial number is 79000. Thanks for everyone’s help
You are right Jim. Engine is 123000,
/ Jd1020 hydraulic problems #31
You're lucky your tractor engine doesn't require the high $$$$ seal
Boom Sprayer (A64127)
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
John Deere Z997R (A60462)
John Deere Z997R...
Komatsu WA250 (A64126)
