JD X595 won't start
/ JD X595 won't start #1
TBS4664
Woodstock VT
JD X595
I was mowing and everything was running fine - stopped the 595 and turned her off - went to start her up again - heard a little "sparking" sound - the dash panel lights flickered for a min' - then nothing... no dash lights - no start - nothing... pulled the battery and made sure it was charged up - checked the 3 fuzes - just put the battery back in - turned the key - one dash light lit for split second... nothing after that... anyone got a suggestion?....... thanks - Todd
/ JD X595 won't start #2
TBS, welcome to the forum. Your JD is newer than mine but I'd look for a fusible link and/or a wire that is shorting out on a piece of metal. If you can put a multimeter on the back of your dash gauges, and then work your way back, that's where I'd start. Has to be a fuse of some kind, can you better describe the "sparking sounds" and did you also get a burning smell with it?
Hi - Thanks for responding... the spark sound was just one very quick one and there was a slight electrical short smell... oddly the fuses didn't seem to be blown - but I replaced them anyway... I'm wondering if it could be a ignition switch issue - ???.....
Club Car Golf Cart (A66285)
Club Car Golf Cart...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A65643)
2013 POLAR TANK...
EZ-Steer Controller and EZ-Steer Motor (A65640)
EZ-Steer...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
Mini Universal Grapple (A65640)
Mini Universal...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
