JD X595 won't start
/ JD X595 won't start #1
TBS4664
Woodstock VT
JD X595
I was mowing and everything was running fine - stopped the 595 and turned her off - went to start her up again - heard a little "sparking" sound - the dash panel lights flickered for a min' - then nothing... no dash lights - no start - nothing... pulled the battery and made sure it was charged up - checked the 3 fuzes - just put the battery back in - turned the key - one dash light lit for split second... nothing after that... anyone got a suggestion?....... thanks - Todd
/ JD X595 won't start #2
TBS, welcome to the forum. Your JD is newer than mine but I'd look for a fusible link and/or a wire that is shorting out on a piece of metal. If you can put a multimeter on the back of your dash gauges, and then work your way back, that's where I'd start. Has to be a fuse of some kind, can you better describe the "sparking sounds" and did you also get a burning smell with it?
Hi - Thanks for responding... the spark sound was just one very quick one and there was a slight electrical short smell... oddly the fuses didn't seem to be blown - but I replaced them anyway... I'm wondering if it could be a ignition switch issue - ???.....
2007 Hooper 20ft Equipment Trailer (A65563)
2007 Hooper 20ft...
90in. Work Bench (A65640)
90in. Work Bench...
2024 CHUBBS GT-612/60 1T/A 12FT DUMP TRAILER (A59914)
2024 CHUBBS...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
17.5X25 industrial tire on Deere articulated loader rim, Coal Valley, IL (A65640)
17.5X25 industrial...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
