JD Gator electrical troubleshooting
/ JD Gator electrical troubleshooting #1
marktoys4
JD gator
I have a 4X2 gator with a Kawasaki engine. The starter will not engage with the key, only thing I get is a click from the solinoid. If I jump the starter it will engage and start. I checked the neutral safety switch and it seems fine, if I use a jumper wire on the safety switch it makes no difference, what else should I try?
/ JD Gator electrical troubleshooting #2
Remove and clean all 4 connection points for the large heavy starter/battery cables.
Or with a volt meter and a buddy to turn the key while you probe for your voltage loss.
ok, update
If I jump the starter wire a jumper wire the starter engages and cranks well, but the engine will not start, even with the key on.
/ JD Gator electrical troubleshooting #4
I do not own that kind of machine but lets look at what you have.
Post #1
( If I jump the starter it will engage and start ) does this mean (start) as in to produce a spark and the engine operates at proper speed.
Post #2
( but the engine will not start, even with the key on.) the word ( not start )
I can not figure out what you are meaning.
How old is the battery ?
When you use your jumper to pull the starter solenoid in have the key set in the run position and have the spark plug boot pulled back and with a know good spark plug lay it against the block and see if you have a spark
To make cranking over easier when testing for ignition if you remove the plug from the engine you will not be fighting the compression ( replace when finished)
My Kohler has a wire to the carb which I think is the fuel solenoid.
Lets try these tests and see what the group thinks.
Craig Clayton
In my first post I meant to say the engine cranks only
with the ignition switch on and by jumping the solinoid wire a jumper wire the engine turns over fine, no battery problems. but will not start.
if I only use the iginition switch I only get the solinoid to click and engage but the starter motor will not turn over.
There is what looks to be an aluminum heat sink attached to the frame that has the a lot wires running through it, I beleive this is the coil. But if there were a failure from the coil the engine would still crank with the key
until I figure out why the engine only cranks with the jumper and not the key,
the spark to the engine is secondary.
/ JD Gator electrical troubleshooting #6
Mark, the item that looks like a heat sink is the voltage regulator. The coil is inside the engine shielding. Here's a copy of the wiring harness, see if it helps track down whats not happening
/ JD Gator electrical troubleshooting #7
Have you measured your battery voltage?? It sounds like it could possibly be weak (low voltage), you should charge it and have it tested with a good tester. If that's ok, then I would check the wiring as suggested for a loose/corroded connection. IF that doesn't turn up anything, then you might need to think about pulling the starter. If it's the kind that has the solenoid on the starter that plunges to engage the bendix (when you turn the key) it might be rusty or binding up inside.
Good luck.
/ JD Gator electrical troubleshooting #8
If I remember correctly this engine has the solenoid shift starter where it's mounted to the side of the starter. There should be one small wire running to the solenoid that runs from your key switch. Crank your engine & make sure you are getting a full 12 volts at that wire. If you are, it sounds like a solenoid sticking of just burnt from use. I would say you are getting voltage because of the clicking. I would fix that first and then further test your engine. Pull the fuel line from the carburetor & crank your engine over to make sure your fuel pump is working. Let us know what ya find with it. Good luck.
Fixed it,
Thanks for the advice. The wire from the switch to the solinoid had cracked and there were only one or two strands connecting the two. repaired the wire and it started.
Mark
/ JD Gator electrical troubleshooting #10
Good deal, always nice to have a simple fix!
/ JD Gator electrical troubleshooting #11
I have a J.D. Trail Gator that starts fine, but when you put it in gear it shuts off. Am I having a safety switch issue? And if so, where is it located? Thanks for your help.
/ JD Gator electrical troubleshooting #12
:welcome: to TBN
What year is the gator?
Are you aware of any safety switches other than "no start" if in forward or reverse? Mine is older 4x2, and that is the only switch I'm aware of on there.
Does it happen in reverse as well as forward?
/ JD Gator electrical troubleshooting #13
Not sure of the year. Actually belongs to my boss. It shuts down in either forward or reverse. My son said that when he was coming to a stop it shut down when he pressed the brake. Thank you for your help.
/ JD Gator electrical troubleshooting #14
But it starts no problem if putting in neutral??
Indicates electrical, shorting out the ignition.
But if "shut down" means it is killing the engine when put into gear, then might be in the tranny and may explain the son's experience when he pressed the brake.
Need more info...
KUBOTA M108S TRACTOR (A64277)
KUBOTA M108S...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2020 Ford Fusion Hybrid Sedan (A64557)
2020 Ford Fusion...
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
