JD 990 is here
/ JD 990 is here #21
Hi Yellowsocks
Do I understand correctly that you work at a JD dealer ??
Do you know what the difference is between the backhoes offered for the compact tractors ? Why is there a specific model for the 990 ? Wouldn't any of the 3 pt backhoes work with any tractor ? Why is the 48 backhoe listed for the 4000 series, and the other xxxxB listed for a 990 ?
Curious
John
/ JD 990 is here
yellowsocks93: Yes on the bucket level indicator.
For what it's worth, here's a copy of a maintenance log I made in Excel from the electronic manual for the 990 on the Deere web site. I printed it on 11x17 and will fill it in as I go.
NOTE: CHANGE THE ZIP EXTENSION TO XLS.
/ JD 990 is here #23
Yep I do work for a JD dealer but I work work in shop washing tractors and what have you. I think the main reason they have seperate hoes is for the fact that the 990 is really just a new 970/1070 tractor which used the 8b hoe. The 4000 series compacts were designed to have the new 47 and 48 backhoes on them. Otherwise JD would have had to modify the mounting frame to fit a 990 or make some sort of kit and not many people buy a hoe for the 990 in the first place. Also the 990 may not have enough GPM at the hydraulics.
/ JD 990 is here
I borrowed a digital camera so now I've a few pics. The first is what I see when I walk up to the machine.
/ JD 990 is here
Next is what the gravel and the huge rock I dug up see coming.
/ JD 990 is here
And last, what the box scraper (when I get one) will see.
/ JD 990 is here #27
Monroe40:
Your a lot younger than I pictured... /forums/images/graemlins/blush.gif but hey the tractor sure looks nice... /forums/images/graemlins/wink.gif
Whiskey
/ JD 990 is here #28
Nice machine. Try not to have too much fun on it.
PENDING SELLER CONFIRMATIONS (A59906)
PENDING SELLER...
Rotary SPOA9-200 Automotive Lift (A59230)
Rotary SPOA9-200...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2013 Toyota Corolla Sedan (A59231)
2013 Toyota...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A60736)
2000 ITASCA...
