JD 755 Project
/ JD 755 Project #41
Lumber bean
The metal plates go behind plastic covers for the selector handles below the front of the operators seat on is for the PTO selector and one is for the speed selector
/ JD 755 Project
Thanks Kellhammer, I appreciate it. I'll try to install them this weekend. I have noticed that when putting the machine in park, the lever can easily get disengaged. I'm not sure if there's a metal plate missing there or not too. Its been a pretty busy month so that's why the lack of updates.
Several weeks ago, my brother and I were able to replace the fuel tank. It was in pretty sad condition. I also replaced the fuel filter and wouldn't you know it, someone installed in wrong. There was a hole on both the top and bottom..... I'm glad I did and it was pretty simple bleeding the fuel lines reading the technical manual.
I must say that I am enjoying using the tractor now. Its nice to be able to start it up and go pick up sticks, move rocks and cinder blocks around. And that leads me to my next question, did they make a special connector for where the drawbar goes? I ask because the drain plug for the hydraulic fluid sits right above where you would put a drawbar and putting a bolt & pin is tough to fit in there. I ended up buying an aftermarket drawbar from TSC Tractor Supply and use a bolt and nut but load the bolt from the bottom. It does the trick but comes loose a lot.
/ JD 755 Project #43
The factory setup for the drawbar is a pin from below with a clip on the top side. It has never come loose and is easy to change between the two holes for long or short bar positions.
Pin A15261
Clip A3581R
/ JD 755 Project
Thanks JD755, I'll check out the pin and clip from my local dealer.
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
UNUSED IRMC HIGH-END MASSAGE CHAIR (A64281)
UNUSED IRMC...
JOHN DEERE 2950 TRACTOR (A63291)
JOHN DEERE 2950...
211297 (A62131)
211297 (A62131)
