JD 650
/ JD 650 #1
jwillh
Couple basic questions about JD 650
Does anyone who has used one feel its too underpowered?
Can someone point me to a site where I can find the specs?
Thanks in advance
Jim Hannigan
Erie CO
/ JD 650 #2
JWILLH: You can find specs for your tractor at www.tractortips.com
I have a JD Model 670, the next generation up from your tractor, with three cylinders instead of two. For me, the tractor is just the right size. I can shred anything my pasture has to offer with a four-foot shredder and I can also mow the lawn with my four-foot finish mower which fits between trees, bushes and fences and which doesn't rip up the lawn. I use a 30-inch rear scoop to transport dirt and gravel and I have a Valby chipper which I use for brush and branches up to 4 inches or so. The Model 670 has turned out to be just the right size for me.
/ JD 650
Also another question- Can an FEL be put on this tractor?
Thanks
Jim Hannigan
/ JD 650 #5
It sounds like you need to sit down with a John Dealer that you feel comfortable with. I believe that a FEL was available, but I can't imagine that it is still being produced for a discontinued model. You're probably going to have to starting looking for an after-market product. By the way, the John Deere Customer Service number is 1-800-537-8233. They're not as helpful as a person might want. They first expect you to contact a local dealer and then they will attempt to answer questions the dealer couldn't handle.
/ JD 650 #6
I used to have a 650 with a fel, backhoe, 5' finish mower, post hole digger,box blade. It was a great little tractor. I wish I still had it. It might have been small, but it would do anything I asked of it, might need 2 bites instead of 1, but I never found a job it wouldn't do. I have 10 wooded acres, about 5 in grass.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
