jd 650 tractor
/ jd 650 tractor #1
waterguy
Maine
Mahindra 2615hst
does anyone know how many gpm at what pressure the pump puts out . my brother wants to mount a 60" agro trend blower on front with a hydro pump will it work?
/ jd 650 tractor #2
This link helps a bit:
TractorData.com John Deere 650 tractor information
The output pressure is 2030 psi, but it doesn't list gpm. That's a good question for a dealer since they should have the service manuals and specs. If the blower runs off a pump, I think the PTO HP might be a more important spec.
/ jd 650 tractor #3
From the tech manual, the 650 has a 7cc pump that is rated at 4.4 gpm at 2400rpm. If it has the optional power steering, a flow regulator limits that system to 1.1 gpm of the gross output of the hydraulic pump.
/ jd 650 tractor
thank you , i will tell him and see if that will run lt.
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
2017 Ford Escape SUV. (A66738)
2017 Ford Escape...
2006 MACK CHN613 (INOPERABLE) (A67714)
2006 MACK CHN613...
2003 NV FLATBED CURTAIN SIDE (A67714)
2003 NV FLATBED...
2011 PETERBILT 386 (A67714)
2011 PETERBILT 386...
New/Unused Electric Winch (A65583)
New/Unused...
