jd 650 tractor
/ jd 650 tractor #1
waterguy
Maine
Mahindra 2615hst
does anyone know how many gpm at what pressure the pump puts out . my brother wants to mount a 60" agro trend blower on front with a hydro pump will it work?
/ jd 650 tractor #2
This link helps a bit:
TractorData.com John Deere 650 tractor information
The output pressure is 2030 psi, but it doesn't list gpm. That's a good question for a dealer since they should have the service manuals and specs. If the blower runs off a pump, I think the PTO HP might be a more important spec.
/ jd 650 tractor #3
From the tech manual, the 650 has a 7cc pump that is rated at 4.4 gpm at 2400rpm. If it has the optional power steering, a flow regulator limits that system to 1.1 gpm of the gross output of the hydraulic pump.
/ jd 650 tractor
thank you , i will tell him and see if that will run lt.
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
1986 Trailmobile 40Ft F71T-6UJA Trailer (A64194)
1986 Trailmobile...
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
