jd 5400 ignition switch - extra wire
/ jd 5400 ignition switch - extra wire #1
captjack
Eastern Shore,MD
jd 5400
I have a 97 ish 5400 open station. I took the panel off that has the ignition switch to add some switches for some LED lights I'm adding. Anywhoo there is a black wire that is not connected to back of switch but it clearly goes to it.
I have surfed the web looking a schematics and picture etc but can't find the answer. I seem to have narrowed it down to 1) Bat 2) acc or 3) ELX (??)
Thoughts ?
/ jd 5400 ignition switch - extra wire #2
shoot me your email, I have a PDF of the technical manual with all the wiring in it
joe
/ jd 5400 ignition switch - extra wire #3
Again, joecdeere to the rescue. :) I was hoping joe would see this and be able to help out the OP.
:thumbsup: to joe
Thanks - i sent you a PM. I talked to JD dealer today - they don't have any idea what it is haha ohh well - see what the manual says.
/ jd 5400 ignition switch - extra wire #5
link sent
got it - still doesn't show this wire anywhere ! Strange - it comes out of the loom with the rest of the wires going to ignition switch
/ jd 5400 ignition switch - extra wire #7
Looking at JDparts the 5400 and the 5210 use the same key switch RE45963. I have attached the page from the tech manual for the 5210 for the switch, that shows where the black/ground wire goes.
  • Key Switch.pdf
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
24in pin on excavator tooth bucket (A61307)
24in pin on...
2016 Kia Forte Sedan (A61574)
2016 Kia Forte...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
1999 Bell B25C 6x6 25 Ton Articulated Dump Truck (A61572)
1999 Bell B25C 6x6...
