Snow Attachments JD 54 snow plow bracket
/ JD 54 snow plow bracket
Well I ground out what was left, and it still didn’t offer me enough clearance to trip 90*. Maybe 70...maybe? So, hopefully that will be enough. Have to wait and see when we get some significant snowfall here. Was in the 60’s this wknd, So I was able to get a ton of stuff done, but I’m sure ole momma nature will let us know that winter is far from over very soon! Good luck with your snow!
/ JD 54 snow plow bracket #22
BCB8564F-6971-4BD2-AFC6-DAA89FAD8CAC.jpeg108F23F6-6A5F-4291-BB33-0DE7203F1747.jpegA74A5E27-600D-47E3-B538-4C4600228EE1.jpeg9977F5B7-4ABE-442E-AE3C-957EB0D739E6.jpegBCB8564F-6971-4BD2-AFC6-DAA89FAD8CAC.jpeg108F23F6-6A5F-4291-BB33-0DE7203F1747.jpegA74A5E27-600D-47E3-B538-4C4600228EE1.jpeg9977F5B7-4ABE-442E-AE3C-957EB0D739E6.jpeg
When I checked, I see that the brace across the bottom of the blade does hit the bracket to limit forward tilt. I hope the first three pictures show that. The last picture shows the hydraulic fittings on the front of the index cylinder. If the temp outside and the hydraulic fluid temp are just right, snow packs in the cavity ahead of the piston and turns to ice and the fitting bends as it gets pushed into the ice and then breaks. You can do lots of plowing without trouble and then it happens. Just something to watch.
Thanks Sno! It’s funny you mentioned that, because I watched a video not long ago and the guy demonstrating his plow had mentioned that and to to also clear the snow out from that area to avoid ice build up. Good to keep in mind while pushing around that white stuff!
Anyone out there have any experience with the poly cutting edge vs the steel cutting edge on their plow? Thanks
2003 Keystone Cougar Model 286 Camper / 5th Wheel (A66285)
2003 Keystone...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
Skid Steer Flail Mower (A65640)
Skid Steer Flail...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
