JD 510 backhoe loader
/ JD 510 backhoe loader #1
tedsan
NAA
I have confused the setup of the 6 hoses that connect the backhoe to the tractor valve. Is there anyone out there that has one of these old ladies that can take a couple of pictures of their setup?
/ JD 510 backhoe loader #2
You may have to resort to purchasing a JD 510 tech manual to resolve your hose routing problem.
I have the tech manual. It doesn't show it unfortunately. If you look closely at the photo, you can see that the valve body on the tractor had 3 hoses up and 3 down. The tech manual only shows it with 6 horizontally, with no arrows.
/ JD 510 backhoe loader #4
Might rig up a pressure gauge that you can plumb in to check which lever goes with which line out. From there, may figure out the rest of them. Or might have to hook up a second one. More work without quick-connects, but should identify what numbers 1 and 2 mean written on the valve.
Or just connect one line at a time ??
/ JD 510 backhoe loader #5
Ports that are vertical to each other on the valve section would feed a function. I.e. section labeled 1 feeds a function, etc. So if you move joystick a known direction one of valve spools will move. That will tell you which function those two lines should connect too. Now you just have trace lines on the hoe to see which hoses are for that function. Getting to operate the correct direction is the unknown but if wrong just swap those two hoses for that function.
40' Shipping Container (A66285)
40' Shipping...
2022 EZ-GO ELITE...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
2011 Ford Expedition SUV (A64557)
2011 Ford...
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
