JD 4310 hydro wont move forward
   / JD 4310 hydro wont move forward
I didn't bypass the seat. It seams to work ok as I can hear a loud click noise in engine compartment when on and off the seat.
tractor is 10 years old. Do you know how to check the sensor.
thanks
   / JD 4310 hydro wont move forward #22
The flywheel sensors seem to last about 10 years. There are actually 2 of these sensors on the tractor, I replaced 1 but not the other. I still get a code for the 1 old one, but it still works fine. Has your seat sensor been bypassed?
later models did away with the flywheel sensor
   / JD 4310 hydro wont move forward #23
thanks
which sensor, seat or flywheel/transmission?
   / JD 4310 hydro wont move forward #25
it may not have the flywheel sensor, later models took a frequency signal off the alternator instead
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
