JD 4300 strange electrical issue, won't start
/ JD 4300 strange electrical issue, won't start #1
atczero
Chattanooga, TN
John Deere 4300
Hello,
I've been a lurker here for a long time and have gotten a lot of good info using the search function.
I have a problem with my 4300 (year 2000 model) and can't figure it out.
While I do all the maintenace on my tractor and can do some small repairs, I am not much of a mechanic and electrial stuff is beyond me.
I have searched here and read all about relays, transmisters, fuses, cut off switches, ground wires etc and the thruth is, I will likely have to have someone come get the thing and fix if for me if I can't come up with something that I can go buy and replace without any major skills needed. :(
Here is the problem. Normally when the ignition switch is turned to the on position, the fuel and temp gages power up, the hour meter comes on and the battery charging light and oil pressure light come on.
Now if I turn the key on, none of those things come on, and none of the other lights on the tractor will come on. The weird part is that if I sit there for anywhere from just a few seconds to 30 seconds or so, I will hear the fuel shut off solenoid click and the instrument panel will power up. At that point the head lights and flasher will work also.
But....when I turn the ignition switch to start I get one loud click, all the lights go off and the starter will not do anything. If I turn the key off and back to on, none of the instrument panel lights or other lights will work. If I leave it alone for a while and come back later and try it again, sometimes the same thing will happen again.
I have tested the battery (with a multimeter and a load tester) and fully charged it and believe it to be ok. I cleaned the terminals and posts. I checked the ground wire conection on the block. It is in neutral and the PTO is disengaged. There is power to the starter solenoid.
If anyone one has any ideas about this I would greatly appreciate any input. Why will nothing work but after sitting there for a while everything will suddenly power up but the starter will not engage?
Is there a way to safely jump the starter solenoid on this tractor? I had a load of pine shavings dumped in the hallway of my barn yesterday and really need to get it moved. I guess tractors never break down at a good time.
Thanks,
Joe
/ JD 4300 strange electrical issue, won't start #2
If you checked/cleaned/tightened ALL FOUR battery cable connections then you probably have a bad battery that will show voltage but won't produce amperage. Try attaching jumper cables from another 12 v battery.
/ JD 4300 strange electrical issue, won't start #3
On my 4310 the fuse panel is below the steering wheel and the fan blows all the dirt and dust across the back of the fuses. Blow all this out with compressed air and the wiggle each fuse in the socket and see if you get the gauges to power up. There is one in the top row(on my 4310) that seems to get a bad connection. I took it out and put in dielectric grease and replaced the fuse and have had no trouble since.
/ JD 4300 strange electrical issue, won't start #4
Tx Jim's suggestion is the first thing I'd try.
Even before you turn the key on, turn your light switch on...headlights come on and bright? If those headlights don't come on, or are dim....quite likely the battery or a bad ground.
Another thing that's relatively simple to get to (after you have eliminated the battery and grounds as a cause) is the key switch itself. There are several wires going into that switch. One may have come loose, one or more may have corrosion, or the switch itself may be bad.
Now, if it was a safety switch, you should still get those instrument lights (but the engine won't crank)...I won't say that eliminates a safety switch, but I'd look elsewhere first.
And, if you don't have the troubleshooting skills, it might be best to let a dealer look at it.
I'll admit, my electrical troubleshooting leave much to be desired. However, I disassemble as little as possible and I am methodical....I also know my limits.
Thanks for the quick replys.
I have checked all four connections and tried to jump start it with no luck.
The strange part is that no lights will work at all with the key off or in the accessory postion. But...if I turn the key to the on position and if the panel powers up (it takes several seconds for that to happen and doesn't happen everytime I try it) then all the lights come on and are nice and bright.
I am going to blow out the fuse box check all the fuses. Have to go to town and get a longer air hose and some new fuses.
I have thought about the key switch. I really don't know how to test it other than just replacing it. I'll see if I can get to it and check all the connections.
Thanks,
Joe
/ JD 4300 strange electrical issue, won't start #6
Thanks,
Joe
Here's the procedure for testing the switch
View attachment Key Switch Test 4000 Series Tech Manual.pdf
It's a pdf file, so you'll need Adobe Reader or equivalent
Roy, thanks for that test info. I'm going to try a couple things first and if none of that works, I will pull the switch and test it.
Edited to ask: Where is the best place to get a tech manual?
Well I removed the key switch and it tested good. I also tested the seat switch and it is good. I'm out of time for today. Hopefully I can spend some time on it tomorrow afternoon.
/ JD 4300 strange electrical issue, won't start #9
From the Deere dealer for the most comprehensive manual.
I'm not too enthusiastic about aftermarket manuals.
/ JD 4300 strange electrical issue, won't start #10
Check your private messages
/ JD 4300 strange electrical issue, won't start #12
I suspect you have a bad battery cable if you are sure the battery is good. Try connecting a jumper cable from the positive battery post to the large starter post. If that makes it start or at least attempt to start, then replace the positive cable. If that makes no difference, try connecting a jumper cable from the negative battery post to a clean ground spot - a bolt with no paing for example. If that makes it start, replace the negative cable.
I'll give that a try, thanks.
Ok, several folks mentioned all the battery and cable connections and I did check to make sure they were all clean and tight. But....for some reason I neglected to check the continuity of the ground wire. Also, when I tried to jump start it, I connected the jumper cable ground side to the battery instead of the frame.
When I finally checked the continuity it was bad so I used the jumper cable to go from the battery to the frame and it fired right up.
If you read my first post, I did mention that I was not much of a mechanic so that is my excuse. :ashamed::confused2:
I really appreciate all the help. I was doing the happy dance standing on the tractor when it fired up!! :cool2:
/ JD 4300 strange electrical issue, won't start #15
Nothing to be embarrassed about...everyone makes mistakes or overlooks things.
The only difference between you and a dealer tech is that the dealer would charge you for an extra hour or two when they screw up.
Just want to say thanks again. If I had not been able to get the info I did from searching this site and more importantly from the people that responded here, I probably would not have kept after it. I would have ended up having it hauled in and repaired and who know how much that would have been. $$$$$$ for sure.
I hope that I can contribute something useful here someday.
Joe
/ JD 4300 strange electrical issue, won't start #17
You just did! :thumbsup:
/ JD 4300 strange electrical issue, won't start #18
It is usually something simple, you just have to find the problem to be fixed? As you just stated you did find the problem
/ JD 4300 strange electrical issue, won't start #19
I had exact same symptoms. Dim dash lights and barely a click and battery showed 12.8 volts. I don’t have a battery tester so i shelled out the Ben bill for a battery and fired right up like it was a new tractor. I was sure it was something much more than a battery because it’s never that simple cut dry for me.
