JD 4200...Front Tires
/ JD 4200...Front Tires #1
billjr
Norwalk, Ct
JD 4200
I have a JD 4200 4wd that needs new front tires. It has R4's all the way around and the backs are just fine, so I'll have to stick with the 23x8.5x12" size for the front. I'm just curious, has anyone tried using the correct size on the front but with HDAP 6 ply tires? Is there any reason why I can't use a different type tire on the front as long as it's the correct size so I don't affect the 4wd operation? I'm kind of trying to stay away from NEW R4's for the front because I drive it across my lawn. I've tried to find used ones with 50% or so to ease the edge or the bars on them (not as pronounced as on used ones), but have been unsucessful.
Thanks, Bill
/ JD 4200...Front Tires #2
As long as the outside diameter of the tires is the same, you will be fine.
/ JD 4200...Front Tires #4
Thanks Tom, that's what I thought.
Yeah, it is just a simple ratio between the two. The fronts go around so many times per every one time the rears go around.
Giyi Gy-72 QA Mulcher (A60463)
Giyi Gy-72 QA...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2023 JOHN DEERE 317G SKID STEER (A62129)
2023 JOHN DEERE...
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2018 Nissan Sentra Sedan (A59231)
2018 Nissan Sentra...
