JD 4200...Front Tires
   / JD 4200...Front Tires #1
billjr
Norwalk, Ct
JD 4200
I have a JD 4200 4wd that needs new front tires. It has R4's all the way around and the backs are just fine, so I'll have to stick with the 23x8.5x12" size for the front. I'm just curious, has anyone tried using the correct size on the front but with HDAP 6 ply tires? Is there any reason why I can't use a different type tire on the front as long as it's the correct size so I don't affect the 4wd operation? I'm kind of trying to stay away from NEW R4's for the front because I drive it across my lawn. I've tried to find used ones with 50% or so to ease the edge or the bars on them (not as pronounced as on used ones), but have been unsucessful.
Thanks, Bill
   / JD 4200...Front Tires #2
As long as the outside diameter of the tires is the same, you will be fine.
   / JD 4200...Front Tires #4
Thanks Tom, that's what I thought.
Yeah, it is just a simple ratio between the two. The fronts go around so many times per every one time the rears go around.
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
LOT: (36) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #2 Grease (A59076)
LOT: (36) 14 Oz...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
Dewalt DWM120 5" Deep Cut Variable Speed Band Saw (A59076)
Dewalt DWM120 5"...
