JD 4200...Front Tires
/ JD 4200...Front Tires #1
billjr
Norwalk, Ct
JD 4200
I have a JD 4200 4wd that needs new front tires. It has R4's all the way around and the backs are just fine, so I'll have to stick with the 23x8.5x12" size for the front. I'm just curious, has anyone tried using the correct size on the front but with HDAP 6 ply tires? Is there any reason why I can't use a different type tire on the front as long as it's the correct size so I don't affect the 4wd operation? I'm kind of trying to stay away from NEW R4's for the front because I drive it across my lawn. I've tried to find used ones with 50% or so to ease the edge or the bars on them (not as pronounced as on used ones), but have been unsucessful.
Thanks, Bill
/ JD 4200...Front Tires #2
As long as the outside diameter of the tires is the same, you will be fine.
/ JD 4200...Front Tires #4
Thanks Tom, that's what I thought.
Yeah, it is just a simple ratio between the two. The fronts go around so many times per every one time the rears go around.
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2013 Dodge Ram Service Truck (A60352)
2013 Dodge Ram...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
