JD 4200 compact won't crank (electrical problem)
/ JD 4200 compact won't crank (electrical problem) #1
Chepstow, Wales UK
JD 4200
Before calling in the local JD agent and putting megabucks in his pocket I am trying to unpick this myself. Engine on my otherwise trusty 13 year old JD 4200 HST compact won't crank. Has been doing this off and on for a while and I put it down to the HST Forwards and Reverse pedals not centering. I've cleaned up the battery terminals, put the battery on charge, checked all fuses - including the 60 Amp one - cleaned up the battery to engine block connection and checked for volts to the starter motor/solenoid. All OK. Getting "clunk" when sitting on seat and turning key (fuel solenoid presumably?) but no starter motor springing into life.
I have no circuit diagram only an "Operators Manual" which came with the tractor (second hand) 8 years ago. I would dearly like to get a circuit diagram because that is the only way I can understand and check the start line circuit methodically. Can anyone help me there please?
My next plan is to check the Diode Block and relays . Then what? Put an earth/negative onto the starter solenoid? ring out the wire from the solenoid to the probable destination? to the keyswitch maybe? That's where I need that circuit diagram most.
Thanks for your help in anticipation.
David
/ JD 4200 compact won't crank (electrical problem) #2
I would pull the starter and have it tested. Or put it on a bench and jumper it to see if it works.
/ JD 4200 compact won't crank (electrical problem) #3
Have you checked all the shutdown switches.
Look at the wiring harness to starter. One of them may be broken.:)
/ JD 4200 compact won't crank (electrical problem) #4
If it is in the budget, I would look at getting the tech manuals at selectmanuals.com for $35.00.
/ JD 4200 compact won't crank (electrical problem) #5
Well, Dave, since your tractor is 13 yo, you will be getting more and more of these electrical problems,
caused by the myriad electrical interlock switches and relays.
Buying a PDF version of the technical manual is imperative if you want to keep your 4200. There
are many pages of electrical schematics in there, including the variations for models sold in Europe,
vs. the USA. You may have to spend a few quid.
You have switches for the PTO, neutral, brake, and HST pedals, as well as a bunch of relays in the
central panel. You can try jumpering the various switches and pulling the relays and cleaning the
contacts, or swapping them around.
/ JD 4200 compact won't crank (electrical problem) #6
Check if you have voltage to the solenoid, you can use a test lite. If you have voltage there its probaly the starter
/ JD 4200 compact won't crank (electrical problem) #7
shoot me your email, I have a PDF of the tech manual you're welcome to. It's the USA one, but I'm sure it would help
Joe
/ JD 4200 compact won't crank (electrical problem) #8
All good advice (especially about the tech manuals...and do have your tractor's serial number handy as there were running changes through the production of the 4xxx series tractors).
If your head lamps and dash lights come on, but no cranking, I'd look into the safety switches first. There's the deadman switch under the seat...easy to get to, so check that one first. The other switches...well, better to have the manual for the locations.
If one of the others who offered the manual can't come through, send me a PM with your tractor's serial number and I'll send the appropriate pages of the manual.
Many thanks to you all who replied with ideas and offers of help, especially to Joe who sent me the tech manual info. That was an eye opener in itself.
Much pondering of the circuit diagram and cleaning up and testing of relays later, wiggling of wires etc. I then asked the wife to listen to each relay in turn to see which one was pulling in when the key switch was engaged. She, brandishing a short length of bamboo stick (to apply to each relay in turn, listening or feeling at the other end) I operated the keyswitch. Engine turned and roared into life. Wife obviously has powers of a witch waving that wand!
However after a 15 minute spell of turning the muck heap over with the loader I then stood up from the seat to dismount the cab and the engine died. Now is completely dead again. So we get closer to the solution... Obviously a dodgy safety switch. Why are they mounted in such cramped and inaccessible places?
I will keep you informed.
Regards to you all.
David
Well I eventually got it all sorted. Initial problem was an intermittent bad connection to the starter solenoid. Can't fix that permanently as removal of that connector means removal of the solenoid/and starter itself which is a major job - the hydraulics pipework is in the way. So I'll have to live with that one. Then the other problem was another intermittent electrical problem! TWO intermittent electrical problems -a nightmare! This second one was the Forward and Reverse pedals for the HST which occasionally failed to return to neutral. Age and lubrication probably at fault there. But knowledge is power!
Many thanks to Joe and all of you who helped me out with useful ideas and technical input. The pdf technical manual is extraordinary. not the easiest thing to read on a computer screen but essential really.
Thanks to all
Regards
David
/ JD 4200 compact won't crank (electrical problem) #12
I don't think its been mentioned I have found connectors on fuses get loose or worn if when it acts up push or wiggle fuses and sometime you find it especially the 30 amp to small of a connector for amp draw, also the back of the fuse box is open and gets a lot of dirt accumulated, take a blow gun and blow it clean,
/ JD 4200 compact won't crank (electrical problem) #13
Is his one of the models that JD made the booster relay kit for.
2017 GENIE GTH844 TELESCOPIC FORKLIFT (A60429)
2017 GENIE GTH844...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
(20) 1/4"-3"X4"X20' TUBING (A60430)
(20)...
Bush Hog 15ft Batwing Rotary Brush Cutter Attachment (A59228)
Bush Hog 15ft...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
KITCHEN AID REFRIGERATOR/FREEZER W/ICE MAKER (A60432)
KITCHEN AID...
