jd 4115
/ jd 4115 #1
font
uk
john deere 4115
Hi can anyone help I have a 4115 that I bought as an unfinished resto project I was hoping to get some photos of the
Alternator bracket in actual situ and pump just want to make sure I put it back together properly. Many thanks in advance.
/ jd 4115 #2
Sorry I can't help you with any pics or first hand knowledge. I'm a fan of the JD4115 though. Please post pictures as you finish the project!!!
Welcome to TBN from across the pond. :)
/ jd 4115 #3
Here ya go. I just went and took these for ya. I hope they show you what you are looking for-
/ jd 4115
20140214_105747.jpg thats great thankyou for your help and quick reply, think im missing a bracket from underneath the manifold. Couple of pics of the project, only a couple of days into it,
/ jd 4115 #5
I'd love to have a cab like that for mine.
/ jd 4115
View attachment 361337 thats great thankyou for your help and quick reply, think im missing a bracket from underneath the manifold. Couple of pics of the project, only a couple of days into it, 20140214_105807.jpg
/ jd 4115
Cheers ill post a couple of piccys,
/ jd 4115
Hi RG1 does the belt tensioner bracket bolt to the water pump?
/ jd 4115 #9
What's the orange colored know up above the steering wheel? is it just laying up there? Never seen anything like that on one here.
/ jd 4115 #10
Sorry to be slow, but I had to run back out to my shop behind the house to check.
No. The tensioner bracket runs over to the engine where it has a double bend in it that goes down and back towards the engine. It has a hole in it that the mounting bolt passes through, where it threads into a hole in the top of the engine below the thermostat housing. If you look at my 3rd picture down from the top, you can see the bend I am talking about in that bracket. That should give you an idea of where to start looking for the mounting hole just below that.
/ jd 4115 #11
Good stuff, great pics. I looked hard for used 4115 when I bought my 2210 but couldn't find one. I think they are a great tractor. Guess that's why you rarely find a used one for sale.
/ jd 4115 #12
That, and the fact that they only made them for about 2 years IIRC. :)
/ jd 4115
20140214_105707.jpg hydrostatic gear shifter H N L.
/ jd 4115 #14
That's what I thought after looking at it some more. Thanks. Did you see my reply to you up a couple posts about the bracket?
/ jd 4115 #15
I'd just like to have something a bit bigger and I think the 4115 fits that need. They seem to be bullet proof and I love their look.
Font's cab rocks!!!!!!!
/ jd 4115
Your alternator looks thinner than mine ill have to wait til water pump arrives to discover how it routes. I added another photo
/ jd 4115 #17
The bracket should still mount to the same point on the engine though. The mounting hole is above and to the left side of the water pump, just below the thermostat housing.
/ jd 4115 #18
I've been pretty happy with mine since I bought it about 4 years ago. I had a 4500 that I bought new before that, and a new 4119 before that.
/ jd 4115 #19
You guys may have already seen this, but here's a great technical data website. Gives all the specs for the 4115 or any other tractor you might be searching for.
You nailed the model run RG1, 2003-2004.
TractorData.com John Deere 4115 tractor information
/ jd 4115
20140217_230436.jpg20140217_230615.jpg ive been back out to the workshop took these pictures, my bracket is straight, ill see if theres any way it bolts on
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2016 Mobility Ventures MV-1 Passenger Van (A66736)
2016 Mobility...
2022 Ford F-250 Knapheide Service Truck (A66736)
2022 Ford F-250...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
