JD 4100 Backhoe
/ JD 4100 Backhoe #1
gkk20012
central Georgia
Kubota L3800, Kubota F3680
I see there are many backhoes available like the Wallenstein and some Woods, 3 pt style and I wonder if a small tractor like the 4100 can accomodate one? In my case, this is for strictly residential home use, not commercial. I do not expect to try to dig out large stumps either, maybe small ones < 12" at the most.
Anyone with a 4100 or similar size tractor have a backhoe on it and how is it working for you?
/ JD 4100 Backhoe #2
Welcome to TBN:D
There are several backhoes available for your tractor, but do NOT get a 3PH mounted one. The good ones will have a subframe that extends under the tractor and attaches in the middle at or near the loader mounts to distribute the load better.
The Woods Grounbreaker Series is a good place to start. You can also get the John Deere #46 hoe to fit your machine.
/ JD 4100 Backhoe
kennyd, thanks very much. I was not aware of the JD46, not sure when they came out with them but I suspect it was after I bought my 4100 in 98.
I always heard the 4100 frame was just too weak to handle the hoe.
But if JD engineered one, I have no doubt it will work with the tractor.
/ JD 4100 Backhoe #4
The 46 came out about 2002-4 maybe? It was available for my 4110 (virtually the same as your 4100) as well as the 2520 tractors.
/ JD 4100 Backhoe #5
DId you ever end up putting the hoe on your 4100, and how is it working out?
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
1975 HOMEBUILT TR-AXLE LOWBOY TRAILER (A64278)
1975 HOMEBUILT...
2015 Polaris Sportsman 570 AWD ATV (A64557)
2015 Polaris...
2005 Dodge Dakota 4x4 Crew Cab Pickup Truck (A64556)
2005 Dodge Dakota...
YALE FORKLIFT (A63291)
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
