JD 3x20 Wheel Spacers?
/ JD 3x20 Wheel Spacers?
Maybe you guys could split a set --- 2 spacers for Fuse and 2 spacers for Roy. Or, anyone wanting 4" wider wheels on a 4x20 series may be interested in half a set. I got the exact same spacers little over a year ago on ebay (skidsteer solutions) and put half set on the 3720 and the other half set on the 4320 so I know for fact it works on both. A set of 4 is now $350 with free shipping (I paid $300 last year with free shipping). Hec, maybe skidsteer solutions will ship half to Roy and the other half to Fuse. They use USPS flat rate shipping with two spacers per box. Their toll free phone number is listed in the ebay ad on the link below.
Skid Steer Wheel Spacers 8 Lug Red 9/16" Skidsteer | eBay
/ JD 3x20 Wheel Spacers? #62
Not quite, I'm afraid...the 4400 tractor has a 6 bolt wheel, the 3720 has an 8 bolt wheel.
Roy, didn't realize you had a 4400. Learn something every day on this forum. Bag that idea.
Fuse, the folks at skid steer solutions may sell just a half a set. Worth a phone call. They are real nice people. Like I said above, they ship 2 spacers per flat rate USPS box. Also, going around ebay you may save some money because skid steer solutions won't have to pay that ridiculous ebay fee.
/ JD 3x20 Wheel Spacers? #65
Roy is right, I have the wheels set all the way out as wide as possible right now. I am moving a lot of farm equipment on and off a trailer using the loader so I want the wide track. I won't need it all the time so I'll change it as needed.
There are a lot of options because I can have zero one or two spacers with the wheels in or out.
The tractor came with zero/ wheels-in which is too narrow for anything.
I did not use blue Lock Tite, I used purple so I could undo it. Also, my wheels are not loaded with fluid so they are easy to move around ( for me anyway).
I use a ballast box. I like to be able to make the tractor light for mowing soft ground when needed.
/ JD 3x20 Wheel Spacers? #66
Sunny I have the same 6-bolt 6" center tires as Roy. I believe their is a market for very heavy extenders approx 15" Dia with the 4" inch center hole and make them 4" thick. Roy and I can keep the valves on the outside and I would get ballast. Wonder if it would be 150lbs each. 300lbs of steel at JD approx price of $1.50 per pound + some centerline machining = $450.00
Also make some for the newer 4000 series 8-bolt
DEAR John Deere:
Report- Request for New Product
OK JOHN DEERE CO. I WANT MINE FOR CHRISTMAS. YOU KEEP THE PATENT/MFG PRODUCT. YOUR CUTOMERS REQUEST A NEW PRODUCT CONTACT YOUR SUPPLIERS.
/ JD 3x20 Wheel Spacers? #67
Hi guys,
I've got a John Deere 3720 with cab and I am very interested in adding extensions.
My tires are not filled but I would like to add some weight so I was thinking about wheel weights.
Any thoughts/ concerns about adding wheel weights on top of the extensions? Is this even possible or does the extension prohibit the install of weights?
Also any thoughts or concerns about my JD warranty? I asked my dealer if extensions would affect my warranty and he couldn't/ wouldn't give me an answer.
Do it. Especially if you have a FEL you really should have weighted rears and ballast box. Spacers also if working on hill sides.
I have a 3720 cab tractor with Rim Guard in rears and wheel spacers. It sure does wonders for stability and safety when working on hills.
Sorry, I can't answer the question of extensions being compatible with weights, ie holes and clearances..
/ JD 3x20 Wheel Spacers? #69
Wheel weights can still be added with the extensions. Wheel weights put all the weight on the wheel and at the point of contact with the ground so there isn't and negative effect on the axle load because the axle doesn't really see the added weight.
/ JD 3x20 Wheel Spacers? #70
Thanks for the quick replies guys.
I've been using the 375 backhoe as ballast but I don't really want to have to worry about putting that on every time I want to use the FEL.
I've got a ballast box on the way but I don;t think the BB on it's own will give enough weight. So I was thinking to add wheel weights and the more I read about the extensions the more I think they will be a good idea.
Also I'm under the impression (maybe I am foolishly mistaken) that wider back tires with extra weight will make the whole ride much more stable (375 BH on or off).
/ JD 3x20 Wheel Spacers? #71
I've just embarked on the spacer road recently, and right now all I feel is insulted. John Deere told me that I bought the wrong tool for my property, that it's my fault that I own an unstable tractor. Jeez, this is western Kentucky - there ain't nothin' flat here. Maybe John Deere just shouldn't sell CUTs here at all. Anyway, I maintain 30 acres of diagonal with my 3720. Fourth tractor I've owned here, and I didn't have any "tippy issues" with the first three. So I first upgraded the 3720 from skinny R1s to wide R4s. That turned out to be a waste of time, because the max R1 rear track of 68.4" was reduced to an R4 max of 59.7 inches. So I added nearly half a ton of liquid ballast to all four R4s. Helped some, but not enough. So I'm moving on to spacers.
I agree with the poster that said there'd be too much stress if you put them on a backhoe-equipped 3x20 series, but feel they're perfectly legit otherwise. Unfortunately, John Deere doesn't. I was told flat out "if you put something on there that you didn't buy from Deere, all bets are off". Once I install spacers, they'll refuse to honor the warranty for any rear drive related issues.
I'm no mechanical engineer, but I'm pretty sure they didn't think through this excuse; the service manager said "it puts too much weight on the (axle) bearing". If I had a backhoe, I'd have bought that. But I don't, and I won't. Besides, they were more than willing to sell me ballasted R1s set out to 68.4 inches. Deere also sells a fender extension to accommodate for that width. My spacer plan will result in R4s set out to 66.1 inches, well within the "authorized" max for R1s. That argument was lost on them.
Spacers simply move the wheels a little farther away from the hubs, there is no extension of the axle involved. Backhoe equipped 3x20s aside, the only weight the bearings support - and by extension the rear axle housings - is that of the tractor itself. Adding a spacer between the hub and the wheel does not increase the net tractor weight. And weight beyond the hub - spacer/wheel/tire/ballast - is supported by the ground. Unless the tires comes off the ground, there is NO additional "weight on the bearing". And the whole idea behind the spacers is to PREVENT the tire from coming off the ground in the first place.
Anyway - I'm going ahead with the 4" (per side) spacer installation, ordered them from the machinist today. I'll also add the "JD-authorized" fender extensions as well. Will update everyone as the situation progresses, but in the mean time I also invite any discussion or comments.
//greg//
/ JD 3x20 Wheel Spacers? #72
66 - 68" will make it much more stable. When I went with the Wide Turf Specials set on wide, mu unit's stance ended up being 66" +. Tractor became much, much more stable.
/ JD 3x20 Wheel Spacers? #73
Greg,
I have 4" on either side of my 3320 and it is a completely different tractor. In average use there is no significant effect on the wheel bearings. The minimal weight of the spacers is transmitted from the weight through the wheel and tire directly to the ground. The only effect is in fact a slight increase in bending moment on the axle, but as you point out, is well within the maximum track of the vehicle.
Mine is out of warranty, but I would not have let that stop me. Just remember to remove them if you ever take the tractor to the dealer for service so you avoid a hassle even on unrelated issues.
I priced wheel extensions for my 3720 cab tractor at two different Deere dealers. One quoted prices from Unverferth and the other quoted a price for the Deere skid steer which will also work. Neither expressed any concern of voiding the Deere warranty and it wouldn't have made any difference to me even if they had.
/ JD 3x20 Wheel Spacers? #75
Yeah, and I brought this up again specifically because of that discrepancy. I've read from many of you that spacers were purchased through - and installed - by JD dealers. Mine stonewalled me, saying it would deny me any rear drive warranty coverage. Taking it to Deere was just as useless. Both dealer and corporate arguments amounted to little more than principle over science.
//greg//
/ JD 3x20 Wheel Spacers? #76
Update: ignoring my written request for assistance in pursuing this as a safety of life issue, the selling dealer added insult to injury by stipulating that they'd require me to sign a waiver - releasing both them and Deere from any liability - warranty or otherwise - resulting from the installation of rear spacers.
Man. Talk about differences between dealers. It's pretty clear that this one and I are done. My spacers are being machined as I write, and I'll simply make an appointment at another area dealer (not affiliated with the first) to have them and some fender extenders installed.
//greg//
/ JD 3x20 Wheel Spacers? #77
//greg//
You might want to discuss this with one of the Deere regional managers.
//greg//
Too bad you ran into that buzz saw. Actually, you could install the fender extensions and the spacers --- not difficult at all. My R4 tires are filled with Rim Guard and I did it with the help of my wife. I also installed wheel spacers on my 4320 with much larger/heavier R4 tires filled with Rim Guard. It's not difficult if you loosen the lug bolts slightly and then jack up the tractor until the wheel just starts to lift off the bolts and then remove the studs. You can then wriggle the wheel back and forth and roll out of the way without letting it fall over. My wife held the wheel upright while I installed the spacers. Then roll the wheel back in place. May have to fiddle with the wheel to achieve alignment of holes and bolts. I used a 2x4 as a fulcrum to turn the wheel slightly to get correct alignment.
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
6x6 Hunting Box Blind (A65579)
6x6 Hunting Box...
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
1995 WILSON PACE SETTER DWH-400 HOPPER BOTTOM TRL (A64277)
1995 WILSON PACE...
Hercules Rustic Gun Safe Holds 20 Guns (A65583)
Hercules Rustic...
