JD 3005 full cage ROPS/FOPS build
   / JD 3005 full cage ROPS/FOPS build #201
I spent today repurposing a wagon running gear from a sileage wagon.
   / JD 3005 full cage ROPS/FOPS build #203
Sorry my friend, I took no pics. It's a Westendorf (Iowa company). I'll take some pics tomorrow. :)
I got the bottom mounting points fitted and tacked
These are the source of the screen/mesh panels
Takes about 30 seconds to collapse or set up
   / JD 3005 full cage ROPS/FOPS build #205
If it helps, I've done a couple of hay wagon rebuilds with threads and pics on this site. Easy search.
Got some gussets welded in at the lower mounting points. Oversized to allow lights to be mounted to them.
Welding is done, cleaned up and ready for paint tomorrow.
   / JD 3005 full cage ROPS/FOPS build #207
Those baskets were a good find Greg. Perfect material for your project!!! Lookin good as always!!!
Despite having to go to my father-in-law's today to work up about 200 lbs of hog meat (cut/wrap, he has cooler/meat house), I still got some paint on...
Got it mounted to the tractor today. Seems the lower mounts 'pulled' a little during final welding, took force to get them to line up. But its on there!
   / JD 3005 full cage ROPS/FOPS build #211
That oughta offer plenty of protection!!!!
I've got a tree puller that I built for my FEL. Modified it to fit 3pt. Use it on the Ford. I NEED one of these Greg!!!! :) Gotta score me some of those collapsible baskets!!!!
Rusty, I'm gonna start screening post to my thread for bad jokes!
Bwahahahaha... Another joke, just as bad as yours! *grin*
   / JD 3005 full cage ROPS/FOPS build #214
Yup, gotta keep your guard up. :rolleyes:
   / JD 3005 full cage ROPS/FOPS build #215
Not sure but they look like tote containers for holding plastic tubs of herbicides or liquid things. I've had some totes that look close to one shown. They should be all over the farm country in the Midwest.
   / JD 3005 full cage ROPS/FOPS build #216
No, those totes are IBC totes. I suspect that his are from "gaylord" wire mesh totes.
Aaron Z
I think theres a tag on the baskets, I'll look and pass on the info.
They are 32" wide, 24" deep, 16" tall, with feet on the bottom that catch the top edge of one below if stacked. Make great potato bins when lined with news paper.
   / JD 3005 full cage ROPS/FOPS build #218
YES, YOU ARE RIGHT!!!!! Knew I had saw something similar, just couldn't remember. I'll go talk to my large farmer friend. Maybe I can score some!!! Thanks for the tip!!!! :)
   / JD 3005 full cage ROPS/FOPS build #219
Should have read down........ I'll try to locate a chemical tote and we'll compare. :)
Here is the only info I could find. Google search of 'palletainer junior' brings up several results.
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A59231)
2018 Regal 29OBX...
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
Kubota L3130 (A53317)
2020 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
