JD 2240 - Fixer' Upper'
/ JD 2240 - Fixer' Upper'
Re: JD 2240 - Fixer\' Upper\'
Well, I worked quite a bit on the tractor cleaning and degreasing when the temp got above freezing, and I changed the oil as well.
In my quest for complete Preventative Maintenance, I have now disassembled the tractor to a point where I have to order some parts so I can put it back together properly. Do it right the first time I guess! It hurts me to have a tractor I can't use for a few days though. I guess I'll have piece of mind when she's started back up.
As a side note, I'm amazed at the availability of every conceivable part from JD, as well as other online sites, not bad for a 20 year old machine.
Happy new Year!
Boots
/ JD 2240 - Fixer' Upper' #12
Fixer Upper? Looks just fine to me. Are you trying to scam your wife a little bit here? Could take hours, days, weeks, months to get the tractor cleaned up and ready for use hon - I'll be out in the shop working on it........call me if you need me.
That size JD is a real workhorse and it will be with you for years to come. My neighbor has had one (a 2240) for 8-9 years that has over 4,000 hours on the meter and is going strong. He's going to repaint it this spring 'cause he wants to pretend he has a new tractor. He does bush-hogging for hire and wants to present a nice image to folks that hire him and figures a new coat of paint will help with that.
Bob Pence
/ JD 2240 - Fixer' Upper' #13
looks like the same tractor i bought last May, without the JD 520 fel; so far i've put quite a few parts on it, new bearings in the front axle pivot point, alternator, water pump, hoses, belt, radiator, front plastic piece, thermostat, fuel pump[this one after i noticed @a gallon of diesel in the oil pan];and am probably looking at brakes soon. sure wish i had spent my 10k elsewhere!! its big enough to do anything i ever want to do, but where are the problems gonna stop??? sure hope yours turns out better!!!
heehaw
/ JD 2240 - Fixer' Upper' #14
How many hours on her and did you notice coolant in the oil pan.
Thomas..NH /w3tcompact/icons/wink.gif
/ JD 2240 - Fixer' Upper' #15
the tach was changed @8 years ago; and don't know if it was the original tach then, so i don't know about the hours; nothing in the oil pan except diesel and oil; now just oil(so far)..i noticed the water pump had a slow drip, so i pulled it off an the local JD shop rebuilt it for $50..changed the alternator to a delco with the regulator built in, noticed the water pump drip while removing the alternator..the tractor starts and runs fine, just with so many problems right off; it sorta makes me leary of whats next!!!
heehaw
/ JD 2240 - Fixer' Upper' #16
Why can't I see the pic?
/w3tcompact/icons/frown.gif/w3tcompact/icons/frown.gif/w3tcompact/icons/frown.gif
I wanna see the pic!!!!!
Keeps telling me... 404 Object not found
/ JD 2240 - Fixer' Upper' #17
TraderMark-
When boots first posted this I could see it. Now I can't see it either/w3tcompact/icons/mad.gif.
Paul
I can't see it either. Muhammed?
I'll try to post it again.
/ JD 2240 - Fixer' Upper' #19
There it is /w3tcompact/icons/smile.gif
/ JD 2240 - Fixer' Upper' #20
The attachments for 2000 were archived... soon we'll organize the good ones into an archive and post that.
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2009 Jeep Patriot AWD SUV (A59231)
2009 Jeep Patriot...
2019 VERMEER LP573 XDT VACUUM TRAILER (A59823)
2019 VERMEER LP573...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
