John Deere 2240 part #
/ John Deere 2240 part # #1
MikeVall
John Deere 2240
I recently picked up a John Deere 2240 4WD with serial # over 350000. I need to replace the part that connects the front tires to one another so the track/steer together. I have looked and looked for this part with no luck. I have a manual and it calls out the part as "tie Rod". With a part number of AR54637. This is not the part I need. I odered that and it was way to short. I believe that was the "drag link".
I need the 60" or so long rod with ball joints at either end that connect to the spindle arms on each side. If it is the "Tie Rod" I sure can't find one or the part number. Here's a picture of the rod... It's bent and being held up with bungee cords.
Any help would be appreciated!
/ John Deere 2240 part # #2
Mike, I believe this is the one you’re after, not that the part number has been superseded
/ John Deere 2240 part # #3
Due to orientation of tie-rod ends & retaining nuts (down vs up) I think AL33289 which subs to AL38369 is incorrect part #. I searched 2240 parts catalog for similar tie rod end in OP's photo with no success.
/ John Deere 2240 part # #4
I did that too, I I gave up and based it on the header of the page-
/ John Deere 2240 part # #5
Can you please post a photo of your tractors serial # tag? If you don't want to post it online please send it to me in a PM. I was employed at local JD dealer from '65-'87 & have more experience looking up JD part #s that the average tractor owner & your tractors front tie rod has my curiosity aroused. I located this similar tie rod that is on a 2040S & 2140 but I'm not 100% sure it will fit a 2040. AL37259 subs to AL178018.
Here's the data plate on the tractor.
Thanks!
Can you please post a photo of your tractors serial # tag? If you don't want to post it online please send it to me in a PM. I was employed at local JD dealer from '65-'87 & have more experience looking up JD part #s that the average tractor owner & your tractors front tie rod has my curiosity aroused. I located this similar tie rod that is on a 2040S & 2140 but I'm not 100% sure it will fit a 2040. AL37259 subs to AL178018.View attachment 4666327
Tx Jim,
Here's the serial number. Thanks!!!!!
/ John Deere 2240 part # #8
The serial Tag definitely shows your tractor is a 2240 MFWD. But I don't understand why the tie rod I posted part # for isn't shown in a 2240 parts catalog.
The serial Tag definitely shows your tractor is a 2240 MFWD. But I don't understand why the tie rod I posted part # for isn't shown in a 2240 parts catalog. View attachment 4668999View attachment 4669000View attachment 4669001
Thanks Tex!
I believe this will work. I measured and from what I can figure out, this will fit. Obviously the one on my tractor is a bit shorter... but due to the bends.
I just ordered one that can be returned if needed. Thanks again!
Weird that it's not listed for my 2240????
Mike
/ John Deere 2240 part # #10
You're welcome
I hope that part fits your tractor. I agree it's weird that part # isn't listed in your tractors parts catalog.
/ John Deere 2240 part # #11
I know nothing about the part numbers and such, but if you just turn that shaft upside down - it sure looks to me like it will work just fine. I think it's just the visible picture that's confusing.
/ John Deere 2240 part # #12
AL37259 specifications I located states length @ 56.25'' while AL38639 is 21''
Thanks Tex!
Mike
Well,
That one was too long and the ball joints were too big to fit in the spindle arms.
I'm at a loss. Just frustrating that the part is not readily in print in manuals or on-line.
And now, I've got her apart and can't move her. Lol.
Time for a beer and some shucked oysters.
Mike
/ John Deere 2240 part # #14
What was part # that ball joints were too large? Have you considered making your own part with new ball joints that fit?
This one (AL78018 )is the one that was too long/large.
Amazon.com
And yes, I may be about to find the ball joints and weld something up.
Thanks for your help...
Mike
/ John Deere 2240 part # #16
You're welcome.
Sorry that I couldn't locate correct length part with correct size ball joint shafts.
2009 IC Corporation PB105 School Bus (A60352)
2009 IC...
Giyi LW45 QA Hydraulic Winch (A60463)
Giyi LW45 QA...
Sdlanch SDLL60 (A60463)
Sdlanch SDLL60...
Sdlanch 20'x20' High End Carport (A60463)
Sdlanch 20'x20'...
SKLP SK-HJ6 40' 6 Section Storage Shelves (A60463)
SKLP SK-HJ6 40' 6...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
