Snow Issue with BX B2672 Snow Blade
/ Issue with BX B2672 Snow Blade #1
CThor009
Kubota BX1880
I am a new sub compact tractor owner. I have a BX with a B2672 Manual Snow Blade. I just recently tried to use the snow blade for the first time, hasn't snowed in over a year. In order to pivot the blade I have to pull the pin out move the blade and put the pin back in. The issue I ran into is the pin is so tight I have to hammer it out and back in. When I looked at it, I found that the holes on the bracket don't line up perfectly which makes the pin stick. Would adjusting the springs on the blade line the holes on the brackets up better? Any other suggestions? I guess I could just get a 1/2 inch pin but would that be too loose? Thanks for any advice.
/ Issue with BX B2672 Snow Blade #2
Do you have a drill , if so clean the holes up?
/ Issue with BX B2672 Snow Blade #4
I don’t know that design and where the springs are as I have the hydraulic version. The right sized reamer it the right tool to improve the miss-alignment if it’s a manufacturing and not an assembly problem. You can do it with a drill bit that’s the same size as your pin, but it might catch and tweak your wrists. Good Luck!
/ Issue with BX B2672 Snow Blade #5
Maybe a round file would work.
Thanks for the suggestions. I'll start small, maybe with a file, and go from there.
/ Issue with BX B2672 Snow Blade #7
As time goes on with use, the holes will loosen up.
What size pin is it now? Metric?
Current pin is 5/8". Was thinking of just trying to find a 1/2" pin.
/ Issue with BX B2672 Snow Blade #9
...or just file down a 5/8 pin as it wouldn't take much. As others have said, taking a rat-tail file to the hole or a 5/8 drill would be the 1st choice.
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2009 IC Corporation PB105 School Bus (A60352)
2009 IC...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
John Deere 4600 (A53317)
John Deere 4600...
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
