Iseki TX 1510
/ Iseki TX 1510
Hi ChrisPerth At the risk of insulting your intelligence i assume you've 'Googled' for iseki parts Australia ? I obtained a User Guide from Yenibiz in Belgium and I think they have other service manuals etc not cheap but you can't get originals any more apparently
/ Iseki TX 1510 #22
Thanks for that I did that but was just hoping
That there might have been someone over
Here.
/ Iseki TX 1510 #24
You might want too try this: Agcopartsbooks.com Log in as a guest, then type in " Field Boss 16 " on right select White from drop down menue .
this should give you 2 listing. select the " 160/185 field boss tractor. Know give this a chance too load up. select something from this menue too look at. IE : engine brakes fuel injection good luck.
/ Iseki TX 1510 #25
I ran across this thread doing a search and I'm wondering if the 1510 comes with a built-in clutch (?) My 2160 has a built-in clutch whereas the older 1300/1500s do not. To check, just put the PTO in gear with the engine off, clutch pedal released, and see if you can freely turn it in the clockwise direction. If not, you should probably add the clutch shown earlier in the post.
/ Iseki TX 1510 #26
Hi , I just joined this forum adn thanks for all the help so far folks. Just purchased a Iseki TX1510 recently with a rotovator - Sr 1100cd attached- iseki tx1510 tractor with sr1100cd rotvator For Sale in Armagh : £2,750 - DoneDeal.ie
I have her working hard but the land/ soil is very hard due to lack of rain recently- 'I know its Ireland I am talking about!'. Could you tell me where to get the service manual for the tractor and rotovator online please as I dont to damage her due to lack of oil at this early stage? I checked the Tractor and the oil seems clean and correct height at the front and back end however the gear oil in the rotovator looks very black and I am not sure how much to top up and whcih Gear Oil to use.
Any advice welcome. Cheers Torin
/ Iseki TX 1510 #27
HI Mitch
I would apprecatiate if you can post those attachements again please as I cant seem to access them. MY PC does not compute.!
Also do you have a copy of the manual please?
Kind regards
Torin Ireland
