Iseki TA207 Connecting rods
/ Iseki TA207 Connecting rods #1
tv3
Kaunas
Iseki TA207
Hello everyone,
I'm quite new to this whole tractor business and, therefore, not too educated about their engines, specially the old ones. I have an Iseki Landleader 207 (TA207) tractor with an E3AG1 Engine (1.429L 3cyl diesel), which has 3 bent connecting rods due to a recent accident.
media-share-0-02-04-7ee9d52695d9fba6b82a1a83f9b542f93105982fb3e42221d20cbb8e6faf1f8c-f9cdea8d-4b.jpgmedia-share-0-02-04-32c2a4d438e3e81a545325b218d76719b85494c83ef3b94a19211f17843e6e9c-c942b48e-ef.jpgmedia-share-0-02-04-c4661109f298abe68b78aa04305dd3210f5355c28bcae496a49ff9e9e04d23b2-94b41931-8d.jpgmedia-share-0-02-04-f43dec2caff000bcb342041deb872a7940bf5c3fe6c7e6ff782daa12b7d6e760-010894da-7a.jpg
So far, my luck trying to find replacement connecting rods has been vague :thumbdown: . Therefore, I come here asking you all whether anyone has experience with this sort of thing?
Do connecting rods from other engines / other manufacturers fit my E3AG1 ?
Should I purchase 3 whole new rods or only 1 and give it to a professional workshop as an example to straighten out the bent ones? Or can I simply find the original blueprints and measurements of the engine parts?
Would a connecting rod from, let's say, a similar 1.5 litre engine fit my engine?
Any ideas where should I continue my search?
Anything helps! If you need any other details, ask away!
I'm not a native English speaker, so pardon for any mistakes.
Here are the approximate measurements of the connecting rod (this one is in best shape) : forumas.jpg
/ Iseki TA207 Connecting rods #2
Hello , you can try on Massey Ferguson Dealers , your Iseki as the same engine of MF 1125
/ Iseki TA207 Connecting rods #3
Or you can try on a Iseki dealer , Iseki TA 525 (european model) as the same engine to
I've tried a certified Iseki distributor in Lithuania, however they did not provide me any support whatsoever, since my TA207 wasn't an European model. Other dealers only sold whole tractors(or engines), rather than parts of it. I'll try my luck today with Massey Ferguson Dealers and asking about TA 525.
/ Iseki TA207 Connecting rods #6
I had one bent rod in a KE70 engine that was found upon rebuilding. I ended up bending it back in a large shop press and it seems to be working fine. Not necessarily a "best-practices" approach and you won't get it perfect but something to consider especially when replacements are apparently hard to source and you should be able to get close enough. However, the rod I had was only about half as bent as the one you have shown. I was worried the bearing ends of the rod would deform upon re-bending as this is what was pressed against but I didn't observe any. If you try this you might want to put the piston pin in just to help prevent the issue.
/ Iseki TA207 Connecting rods #8
Here is the original file of the iseki TA 525 which has a motor equal to yours, you can go to an Iseki dealer and ask the number 6
/ Iseki TA207 Connecting rods #9
If you haven't found rods email me. I have US & Japanese sources.
2017 Mercury SeaPro 115HP Outboard Boat Motor (A61574)
2017 Mercury...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
Deere 333E (A60462)
Deere 333E (A60462)
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
