Is this really a grease fitting?
/ Is this really a grease fitting? #1
TVZ
MF 1726E
This (attached) is the guard on the shaft of my brush hog. The thing surrounded by red looks kind of like a zerk fitting. Is that what I use to grease the shaft? Or do I need to get the guard off or somehow access a fitting on the shaft itself?
/ Is this really a grease fitting? #2
Yeah, I think that is for lubricating the plastic collar on the PTO shaft. I used to grease it, but don't anymore.\
Cheers,
Mike
  • Good Post
Reactions: TVZ
/ Is this really a grease fitting? #3
This is what you need to grease those.
  • Good Post
Reactions: TVZ
Cheers,
Mike
If that's for lubricating the collar, is there a zerk fitting somewhere for lubing the actual shaft?
So you poke this thing through the plastic fitting on the guard, and just let the grease go into the area inside? Is there a zerk in there?
/ Is this really a grease fitting? #6
Yes you just poke it in and pump grease. For the shaft look on the U-joint. you should have a 45 degree fitting to grease the U-joints. Should be one on both ends of the shaft.
/ Is this really a grease fitting? #7
As Mike noted, that is for greasing the plastic collar. I've always just used a grease gun on mine. It holds on fine.
I grease that, the u-joints (there is a zerk in the middle of the joints), and occasionally I pull the shafts apart to put a little grease on them to keep them from rusting and freezing up (I've not found it necessary to do the shaft very often. I just check it every few years.)
/ Is this really a grease fitting? #8
I went with a little bit less sharp option, works well, used it last week on the same plastic collar.
Rather than poke through, just press against as the tip is flat.
/ Is this really a grease fitting? #10
On my equipment there is a ring with a step in it on the pto shaft that another ring in the guard, with a step rides in.. The grease goes in-between the rings, or close enough to keep all turning more easily than without grease..
It is all plastic on plastic and eventually will ware out, so some lube will not hurt..
My 5 cents of experience....
/ Is this really a grease fitting? #11
I pull my PTO shaft apart every three or four years and grease it all down. Wipe down, clean and grease the male & female ends - grease those plastic zerks on the collars - grease the zerks on the U-joints. Eventually the plastic shaft protector will ware out but cleaning/greasing seems to extend its useful life. Actually - I grease the U-joints annually.
2015 WINSTON TANDEM AXLE 24FT EQUIPMENT TRAILER (A66091)
2015 WINSTON...
2012 INTERNATIONAL PAYSTAR 5900I (A67714)
2012 INTERNATIONAL...
2012 Chevrolet Impala Sedan. (A66738)
2012 Chevrolet...
2016 Chevrolet Colorado Crew Cab Pickup Truck (A66736)
2016 Chevrolet...
2013 FORD F-150 (INOPERABLE) (A67714)
2013 FORD F-150...
500 BBL WHEELED FRAC TANK (A67714)
500 BBL WHEELED...
