Is this going to work?
/ Is this going to work?
In looking at your original post, I think your original idea is just fine. If you came up with that configuration on your own, you obviously know what you are doing. I suggest you go with that tractor if it is still available. It is certainly within your budget since you suggested it and it will do a fine job on your driveway. It may take a little more time than a bigger high-powered machine.
Kubota B3030 HSDC snowblowing Jan 2012 (HD) - YouTube
I did a good bit of research and talked to some locals before I ever posted here. I do think I'm gonna go ahead and step up to the l4240 though, i think the B2920 would work hp wise, but i'm concerned that it won't have enough weight to it. All the hp in the world is useless if you can't get it to the ground.
/ Is this going to work? #82
I'll repeat my credentials for giving advice since I don't find snowblowing advice from people from the south to be particularly credible. I've been snowblowing for 30 years and we get 10 to 30 feet a year, so I think I understand what is needed for snowblowing.
Oh snap, oh no you didn't! :laughing: Yeah, I agree, don't listen to someone from the South since WV isn't part of the South. So never ever ever never listen to someone who's plowed snow down here. Especially when snow is usually heaver per cu/ft in the south than the white puffy powder of the north.
What is this white stuff you speak of... :D
/ Is this going to work? #86
1 weeks worth.
/ Is this going to work? #88
Now that's what I might be inclined to call a dusting, albeit a little thick!:laughing::laughing:
-What a beautiful place!
/ Is this going to work? #89
That was last year and I know it wasn't much by many standards. I think that snow was a 10 incher. About three weeks after this we had another 14", 18" in the lower areas which is pretty big for around here.
This year we haven't gotten any at all. :( I like playing in the snow!
/ Is this going to work? #90
I'll repeat myself: I believe you want something to deal with the weather and options range from my el-cheapo tuf-top canopy and jury rigged golf cart cover...all easily removable, to a full factory cab, but you want something.
Loaded rear wheels and chains on all four wheels. Forget the baloney about one or the other axles winding up in 4wd ...just not enough traction, speed, or power to cause trouble. But, at purchase time, make sure that, one way or the other, you have the clearance for chains!
Wider blower on the rear (find another use for the saved money, like biger tractor/blower)...a little practice and it's not hard at all to drive "side-saddle" (assuming that you pre-placed wands at the sides of your drive, as I had recommended above). You are creeping along, after all; this is not like reversing your car or truck up/down the driveway. And there is no need to drive over the snow to blow it (as you would with rear mount forward facing blower) and you can have a FEL on the front. You might think it would be a little easier to get in trouble when reversing, but think of how easy it is to get out when your blower is on the rear...you just turn around, not the tractor and, the FEL can get you out of any bigger problems.
You want HST (or a creeper gear or a clutch mechanic on duty.) With HST you can ease in at full PTO power and take on any depth/density.
If your FEL is quick-attach, you could swap the bucket for a plow, even a hydraulic V..
I had a few other suggestions, but don't want to repeat myself (too much)...my situation is quite similar to yours and I went through all the same decision alternatives.
/ Is this going to work? #91
We live in CT with about 1/2 mile of paved driveway and private road. The driveway is very steep but the road is pretty flat. We tend to get 5-12 inch storms, usually wet snow. Usually most of the snow melts before the next storm. Last year was seriously weird with multiple 24+ inch storms and accumulations over 4 feet with even higher banks. So I have some seat time moving snow.
If you already have a 4wd pickup can you add a plow? It will be faster and more comfortable than a tractor. If you want to go the tractor route consider a plow instead of a snowblower. A plow will leave banks while a snowblower won't. BUT - if your snowfalls don't accumulate too much the banks aren't a problem and the plow will cut at least 1/3 off your clearing time. Don't go by last year only as the east coast had abnormal snowfalls last year. Also, don't underestimate the importance of a cab. Is your wife going to want to spend 1-2 hours on an open station machine, in the dark (plowing usually happens before leaving for work or after getting home), in the cold getting snow blown into her face and dripping down her neck? I did that for years and it gets old. Last year we moved to a L5240 cab and I would never go back to an open machine. Good luck in your decision and that property looks beautiful.
/ Is this going to work? #92
For your wife's sake get a cab with a heater. You are looking at this as an adventure. She sees it as work to get done. Don't assume she'll be able to stay warm. Then throw in the days when a person isn't feeling so great, but that drive still has to be cleared! It is a lucky person that enjoys their chores, but not everyone does. I don't have that much to clear, use a 7' plow with an open tractor. Takes me 3-4 hours to do the house and barn. I dress warmly and I still freeze for the last two hours- and that is in 15 degree weather. I wouldn't ask my wife to do it the plowing though she has asked about it. The cab will hold the heat in from the heater.
at this point (after yesterdays tractor shopping)
I'm leaning toward the Kubota L4240 with a cab
options and attachments, undecided
mostly likely the front mount blower,
/ Is this going to work? #94
Pick up a camera, too. We're going to need plenty of pictures to go with the story.
And before I forget, check your Kubota front axle oil after an hour or so--they always seem to need a fair amount even though they show full when you first get them. Beats me.
I've got a couple of real estate deals that I have to finish up before I make the purchase, it may be a few weeks yet.
/ Is this going to work? #96
did you think to check the wheel clearances on the tractor you are about to buy...and which, it sounds like, will want chains on all four feet.
yep i already thought about clearances, some need spacers some don't,
thanks for reminding me though
/ Is this going to work? #98
Sounds like a good choice. The front blower does add a little cost but this setup should last you a lifetime and the comfort factor of having the front blower will be something you will appreciate over time and the additional initial cost will be forgotten.
/ Is this going to work? #99
The 5240 with R4s has clearance for rear chains only if the wheels/rims are set all of the way out. The 4240 is (I think) the same frame size so it probably needs wheels/rims set out also. Have the dealer do this as these tires are heavy - before you add any weight to them. Can't help with front chains as I don't have them. 500 lbs hanging off the three point was not enough weight for rear traction. I added 50% fill of Rimguard to the rear tires (400lbs-tire, 800 lbs total) and that helped some. Rimguard and weight in back was better. The tractor does leave depressions in wet ground though. I am going to try siping the tires for next winter. Good luck.
/ Is this going to work? #100
Regarding extra weight, I have no experience with blowing snow but wonder if you get the same effect in snow of wheel weights as opposed to loaded tires. I have bad memories of loaded tires and won't do that again. Wheel and front end weights work for me in dirt so how is it with snow? Is "weight" weight no matter how you get it?
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
5ft Frontier Rotary Cutter (A65579)
5ft Frontier...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
John Deere 2 Row Planter (A65640)
John Deere 2 Row...
IRanch High-End Tricycle (A64119)
IRanch High-End...
