Is there potential?
/ Is there potential? #1
brianMO
Missouri
TYM T330 w/ lt300 loader
I have been looking for a way to transport my new T330. With loader and filled tires I feel I need at least 10k for capacity. With implements we are talking about 5500lb plus. I ran into this trailer on Craigs. It is homemade, but appears built like a tank. I own a 2500 dodge truck with Cummins diesel. I know this is going to be extremely heavy. He wants $900.00 for this. I know there will be a project involved. Comments please.
This trailer is 8X20feet. Would it be difficult to make it a gooseneck?
/ Is there potential? #3
GN modification will depend on what the frame looks like. I'd guess 10-20 blacksmiths hours + materials would get it done.
Personally I'd pass on it because a tri-axle runs down the road smooth but destroys tires on corners.
/ Is there potential? #4
From what I can see in the pictures at $900 plus tires, brake & bearing service, lights & wiring, and possible change to gooseneck - why? Their are too many good trailer deals in Mo. I'm thinking of making a trip to Sikeston myself.
Also tri-axles can be tough on tires unless really needed for GVW.
/ Is there potential? #5
I would pass also. 7 new tires, one for a spare, you are looking at $600. New bearings, you are looking at $200. New lights, wiring, battery, break away, you are looking at $200. Lets not get started on the brakes.
As mentioned before take a trip to Sikeston, MO.
That trailer is worth more as scrap steel with the prices today.
Chris
/ Is there potential? #6
As an engineer, I don't agree with the build of the trailer from the outside. Maybe the frame is stronger than it appears but it looks like a trailer that weighs 4000 lbs with a GWVR of 10K lbs. The jogs in the outer W beams would make the trailer weak if they are the main load carrying components.
A stronger, lighter manufactured trailer is what you need. There are plenty of used 10K lb dual axle trailers out there with decent components for not much more money. I just bought one myself for $600 (a 7K lb trailer) that only needs wood and tires. It was more convenient for me because I already have the wood and tires.
Plus, look at the deck of that trailer. Smooth steel with no grips. A slight amount of mud or water will cause your tractor to slide off. Wet steel is extremely slippery. That alone would make me pass on the deal.
Thanks for the feedback. I think I will pass. That is what I was wanting from you guys. Good honest opinions. I appreciate your time and response. Gotta love this forum! I will keep looking.
I am going to look at this after work. He says some of the wood needs replacing. Broken tail light, and could use some tires. He is going to throw the chains and brake controller in with it for $850 as well as the pindle receiver w/ 2 5/8 ball. What do you think? No ramps but I weld and have the material to do it. Is it worth looking at?
/ Is there potential? #10
The neck on that is braced nice, but it is some small steel. Most 10k trailers have 2"x6" channel. That would be a 14k with what looks like 1&1/2" x4" channel.
Seriously, "bargain" trailers are not a bargain! Check the tires. You probably will need 4, figure that costing $400 for some cheap ones mounted. The brakes are probably toast. Figure on $200-400 depending on if you need just magnets, or machining too. The bearings and seals may also be toast. The wood looks like heck. Hows the lighting and wires? I would guess that you would need to add 800-1000 to that trailer to get it road ready.
Included is a link to our local-ish trailer place. a new 10k 20' tag trailer is 3500. Your local prices may be higher or lower.
5 Ton Equipment Trailer, Johnson Trailer, Colfax Wisconsin
/ Is there potential? #11
I had a 45' commercial boat hauling trailer with a 5th wheel that I cut the 5th wheel off and made a regular tongue with a pintle hitch. Could have traded that first one and saved me a bunch of work, as it is now a 20' flatbed with a 12' dumpbed.
David from jax
/ Is there potential? #12
Looks like an under engineered over built way too heavy probably not that strong trailer that will end up costing way more than its worth to make right. If it looks like scrap steel in pictures it probably is in real life.
/ Is there potential? #13
The second one doesn't look to bad, but it clearly state that its a 7000 lbs trailer. Its also listed as both a 16 and 18 ft trailer. Kind of a funky design. To light of a trailer and possibly to short? Don't forget that when they say 7000 or 10,000 lbs, that means gross trailer weight, not carrying capacity. So the second trailer may only carry 4500 lbs of equipment.
/ Is there potential? #14
The second one looks to be a landscape trailer with a funky railing. Trailers are something that you almost have to buy new to avoid some cobbled up mess IMO.
