Is black smoke a problem while snowblowing
/ Is black smoke a problem while snowblowing #1
Saitcho
Quebec
Kubota B26
I have a Kubota B26 TLB that blow black smoke if I push it too much, is that bad for the engine? During normal snowblowing operation everything works fine but If I go a little too fast I can hear the engine tone change slightly, RPM are not dropping, and the black smoke starts to comes out. That's my sign to slow down a little. I could get the job done faster with the black smoke coming out but was wondering if its bad for the engine or not.
/ Is black smoke a problem while snowblowing #2
Without knowing more I’d say it’s normal. As you load the snowblower down the engines governor asks for more power to the point you are hitting full power.
/ Is black smoke a problem while snowblowing #3
Sounds normal to me for non-emission control diesels. I believe that applies to your B26 TLB.
Kubota - and others - did experiment with retarding the injection timing to reduce nitrous oxide output back when NOx was regulated but visible smoke was not yet regulated. Retarding the timing a couple of degrees did reduce NOx, but also increased visible black smoke during RPM changes and when starting. That was all back in the Tier IV Interim period roughly 2007 to 2012- and it led to the full Tier IV "visible smoke" restrictions we have now.
I know about that because we have one of those Interim engines (2008). Works fine, but you do not want to be downwind when it lugs and then revs. Smoky and stinky. I've worried about it carboning up the engine and exhaust, but so far @ 1100 hours of mostly low rpm running the motor runs exactly as it did when new. I do try to change the engine oil and filter every year or two.. Or if hasn't been used much, just the filter. I use name brand full synthetic engine oil, 5w-30 or 5w-40 & Kubota filters.
I'm also pretty picky about the fuel.
rScotty
/ Is black smoke a problem while snowblowing #5
Yes some smoke is normal when under load - i just slow down a bit. I plow in high range some times and if it starts to smoke I slow down. Most of the time I am working in M as a rule and it doesnt smoke.
/ Is black smoke a problem while snowblowing #6
Are the RPMs dropping significantly when you see the smoke?
/ Is black smoke a problem while snowblowing #7
The exhaust side of my front blower is pretty dirty come spring.
Normal-gets a good scrubbing!
/ Is black smoke a problem while snowblowing #8
It depends on the engine loading and rpm.
Proper tuning should yield NO smoke BUT most people just crank the fuel and let it roll coal
Mechanical diesels are a little different since they dont have as precise tuning.
Excess smoking can create higher EGTs which on a turbo engine is bad
Gale banks has many hours of good lectures in diesel tuning
/ Is black smoke a problem while snowblowing #10
Excessive smoke and high EGT are bad on N/A engines too.
We’ve seen really high
EGT/combustion temperatures on completely stock N/A mechanical diesel tractors operating in high elevations.
Adding a Turbo and leaving the fuel system stock (no additional fuel) will significantly reduce EGT/combustion temperatures, increase power and reduce/eliminate smoke in those conditions.
Mike
/ Is black smoke a problem while snowblowing #11
Heck, I can make my M9 blow smoke with the Lucknow on the back if I push it too hard. Pretty normal for a pre-4 engine.
If it blows smoke, it's telling you to back off a bit. Real simple.
/ Is black smoke a problem while snowblowing #12
Are you ingesting snow dust in your air intake to the filter while blowing? Black smoke could also be a sign of reduced air flow.
I helped a farmer out years ago. He had his big Deere utility tractor back to dealer and they did everything to it and the guy was still having issues with blowing.
I told him he's freezing his air filter and sure enough that is what it was. After all the money they spent replacing injectors, and playing with the fuel tank and fuel pump, LOL
/ Is black smoke a problem while snowblowing #13
When plowing snow with the big trucks we would put burlap bags over the air cleaner so they would not fill up with snow..
No snow ingestion.
/ Is black smoke a problem while snowblowing #15
I'd say it is tuned about Perfect.
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
UNUSED FUTURE FT-72-72" HYD MULCHER (A60432)
UNUSED FUTURE...
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
