Inverter for truck
/ Inverter for truck
Thanks everyone, going to scrap the inverter idea. Will probably just buy a new Honda or Yamaha generator so that I can use it without going deaf as well as at campgrounds to recharge the camper batteries as needed. Will cost more upfront but from the sounds of it would be a better setup long-term.
As far as why I want a compressor in the truck it is for farm use. Would love to be able to use air tools for field repairs, changing wagon tires and blowing dust and chaff off the baler.
/ Inverter for truck #23
/ Inverter for truck #24
There is another way to do it.
I have one of these mounted in a 6 wheel ATV. It gives me 20 amps at 220 volts that will go anywhere. The only issue is that you have to set the engine rpm fairly accurately to get 60hz power out of it.
I have seen one rigged up in a pickup with an air conditioner clutch to turn it on when needed.
/ Inverter for truck #26
12 volt Impact Wrench, Leaf Blower works great
/ Inverter for truck #27
Meh, we have the smallest handheld Stihl gas blower and its great for blowing out the baler. It won't get quite everything that a blowgun will get, but it works well.
I have heard good things about some of the other cordless impacts as well (not that they will do much for a flat tire).
Aaron Z
/ Inverter for truck #28
In 1990 I added a 2000W inverter and a second battery to my service van along with a retractable corded trouble light/extension outlet.
I do run a small Emglo compressor which is just about the max... compressor and inverter are now 25 years old.
Spent $1200 for the Inverter and $450 for the compressor back them.
In a pinch, the compressor is large enough to run my Senco Underlayment Stapler and Brad Nailers...
I also added a continuous duty 12 volt solenoid so with the push of a button both batteries can be joined which also brings in my 120amp or 130 amp... can't remember anymore... alternator... wanted to go bigger and learned I would need to double belt it... the only I put in was for ambulance duty so it has good low rpm output...
I can pull the inverter with the second battery out as I used a plastic boat battery box and heavy duty commercial jumper cable disconnect...
Sometimes I just needed to run a skill saw or sawzall or lights and it has worked great... will also run my Spartan 300 cable sewer machine...
/ Inverter for truck #29
Meh,
Aaron Z
Yes Sir, Keep her tiddy in the field, get them nooks and crannies at the barn to prep for storage.
Aaron Z
Cordless, cords for me. Those small batteries are a waste for infrequent use and they are expensive.
(truck bed or trailer then to the barn or a tire shop to fix a flat tire!, 18.4x38 are a pain)
/ Inverter for truck #30
Since the OP is leaning towards a small genset, I will throw it out there that I made the mistake of buying a cheap knock off genset years ago.... It was loud and lasted less than 100 hours. It was also a REAL pain to start after a short while. Ended up with a Yamaha 2000, and 3000 (RV air conditioner). For a less expensive alternative to red/blue, the Champion inverter gensets are very well reviewed by users over at the RV.NET forum.
I've been wondering about the Champions, my biggest concern is noise, it needs to be extremely quiet for when needed at campgrounds. I will start doing more research on them as their much better priced than the Honda and Yamaha units. Thanks
/ Inverter for truck #32
I bought a champion 8000w in the summer of 2012. Used it about 40 to 50 hours the first few days after we got it due to power outage. It sat about a year, used it a few more hours for another power outage. Sat for another year, dead of winter, power outage. Ran for about another 24 hours, not continuously, and the motor locked up. Less than 100 hours total run time, always fresh fuel and full of oil. Over 2 years from purchase date, no warranty help.
/ Inverter for truck #33
^^^ I was given one when a neighbor moved... worked real well and not loud.
Used it a few hours every couple of months... then it would not start for love or money... tried a little starting fluid and kicked right off... fuel flows.
The small engine shop said he had about a dozen to repair saying reformulated fuel issues...
/ Inverter for truck #34
I like the engine driven generator head idea. It probably wouldnt fit in many engine compartments (especially V-8 or V-6 engines), but should be fine in my Cummins Dodge.
Has anyone else gone this route?
/ Inverter for truck #35
The one that I saw was in an older ('80s) 4 cyl Toyota pickup. He used an AC clutch to turn the generator on and off. The bracket looked like it may have been for an AC compressor.
/ Inverter for truck #36
Duplicate!!! Why does this site insist on doing that??
None, of us really know.. It started a few years ago, from a software upgrade on the forum software, and it has been with us ever since.. You can delete the extra posts, and I usually do, but nothing I know we can do to stop it.
/ Inverter for truck #37
I tried to do that, but I can't get "Delete Post" to work.
/ Inverter for truck #38
After you hit edit, you have 3 more buttons to press.. Delete, delete message, and delete down at the bottom... So delete, delete, delete.
/ Inverter for truck #39
Yep, that worked! Thanks!!!
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2021 KENWORTH T680...
2021 Honda Pioneer 700 4x4 Gas Utility Cart (A59228)
2021 Honda Pioneer...
2017 HAMM H5i P PADFOOT ROLLER (A60429)
2017 HAMM H5i P...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
