installing gauges
/ installing gauges #1
speedy2
yanmar ym1500
Is it a good idea to pull fuel tank on ym1500 to get to the back of the dash to install oil pressure and temperature gauges? Thanks Speedy2
/ installing gauges #2
Didn't have to on mine. There is plenty of room to work with everything in place.
/ installing gauges #3
Nope. Plenty of room to work on the 1500. I've installed battery volt, oil and temp on mine. Only thing I did was pull the steering wheel to drill the holes.
/ installing gauges #4
i didnt even pull the wheel! i found more than enough room to drill and work
/ installing gauges #5
I was able to drill holes and work with everything in place as well, ym2210
/ installing gauges #6
... if you have small hands! ....:D
although I have not installed new gauges on my 180D; and Id like to; its a good idea; I have had the front plastic dash off to repair wiring; I could not access the wires properly with it in place and never managed to get the steering wheel off after much WD40; puller, grunting and even tried hammering a chisle between the steering wheel and the housing to no sucess ... only reason I got it off was it was a broaken dash at the steering wheel.
2005 John Deere 225CLE Hydraulic Excavator (A66734)
2005 John Deere...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2020 Ford F-150...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
GENERAC MOBILE  MTL65 LIGHT PLANT (INOPERABLE) (A68842)
GENERAC MOBILE...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
