installing gauges
/ installing gauges #1
speedy2
Member
yanmar ym1500
Is it a good idea to pull fuel tank on ym1500 to get to the back of the dash to install oil pressure and temperature gauges? Thanks Speedy2
/ installing gauges #2
Didn't have to on mine. There is plenty of room to work with everything in place.
/ installing gauges #3
Nope. Plenty of room to work on the 1500. I've installed battery volt, oil and temp on mine. Only thing I did was pull the steering wheel to drill the holes.
/ installing gauges #4
i didnt even pull the wheel! i found more than enough room to drill and work
/ installing gauges #5
I was able to drill holes and work with everything in place as well, ym2210
/ installing gauges #6
... if you have small hands! ....:D
although I have not installed new gauges on my 180D; and Id like to; its a good idea; I have had the front plastic dash off to repair wiring; I could not access the wires properly with it in place and never managed to get the steering wheel off after much WD40; puller, grunting and even tried hammering a chisle between the steering wheel and the housing to no sucess ... only reason I got it off was it was a broaken dash at the steering wheel.
2014 CATERPILLAR 320EL RR EXCAVATOR (A65056)
2014 CATERPILLAR...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2004 CHEVROLET MALIBU 4 DOOR CAR (A66091)
2004 CHEVROLET...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2007 STERLING LT7500 SERIES CRANE TRUCK (A67714)
2007 STERLING...
213137 (A64276)
213137 (A64276)
