installing gauges
/ installing gauges #1
speedy2
Member
yanmar ym1500
Is it a good idea to pull fuel tank on ym1500 to get to the back of the dash to install oil pressure and temperature gauges? Thanks Speedy2
/ installing gauges #2
Didn't have to on mine. There is plenty of room to work with everything in place.
/ installing gauges #3
Nope. Plenty of room to work on the 1500. I've installed battery volt, oil and temp on mine. Only thing I did was pull the steering wheel to drill the holes.
/ installing gauges #4
i didnt even pull the wheel! i found more than enough room to drill and work
/ installing gauges #5
I was able to drill holes and work with everything in place as well, ym2210
/ installing gauges #6
... if you have small hands! ....:D
although I have not installed new gauges on my 180D; and Id like to; its a good idea; I have had the front plastic dash off to repair wiring; I could not access the wires properly with it in place and never managed to get the steering wheel off after much WD40; puller, grunting and even tried hammering a chisle between the steering wheel and the housing to no sucess ... only reason I got it off was it was a broaken dash at the steering wheel.
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A64553)
2025 Wolverine...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
2011 FORD F-350 FLATBED DUMP TRUCK (A64278)
2011 FORD F-350...
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A67147)
2018 FREIGHTLINER...
